Issue with Compiling OFS Agilex PCIe Attach on F-Series Development Kit
Hi Raizz,
Sorry for the wait, was setting up the server on ubuntu with the relevant Quartus and OFS version. I've tested 3 times and unfortunately I don't see the "hang" part though, the part where it "hangs" passes without issue on my side although on the particular FIM version 2023.3 do have compilation error at later stage (seems mentioned in release notes)
From your log
On my side
but eventually compilation will fail with error (after around 1hour + into the compilation, average it will take around 7-8 hours on my system on Xeon processor)
might be due to this
I will check with OFS team on this but I think the main focus is getting the compilation to work ,so probably will focus on 'freeze/hang' at the qsys-generate.
When you mentioned stuck for hours, may i know like the exact/estimate time on how long like how many hours? I'm wondering whether to leave it much longer and see whether the qsys-generate will complete (it is depending on processor type on how long the duration)
Kian
Hi Kian,
Thank you for your reply.
Based on your previous message, I moved to the Intel OFS 2024.2-1 version and installed Quartus 24.1. I followed the guide here
" https://ofs.github.io/ofs-2024.2-1/hw/ftile_devkit/dev_guides/fim_dev/ug_ofs_ftile_dk_fim_dev/ "
Initially, I built the default F-Series DK design, but I encountered some compilation errors. I then tried the Flat FIM and faced different issues, so I moved on to the HE_Null FIM.
However, I am still encountering issues during compilation. I've attached the logs for your reference:
F-Series DK : build_fim_work_fseries-dk.log
Flat FIM : build_fim_work_fseries-dk_flat.log
HE_NULL : build_fim_work_fseries-HE-NULL-dk_flat.log
Thanks and regards,
Raizz
