Issue with Compiling OFS Agilex PCIe Attach on F-Series Development Kit
Hi Raizz,
Thanks for using Intel Forums, I'm Kian and will be looking into this case.
I saw the log that you provided, looks like the compilation just stalled at that location and seems to be truncated/incomplete (eg sudden stalled) without error
Info: qsys-generate /home/admin/SmartNIC/Intel/Intel-agilex/OFS_BUILD_ROOT/ofs-agx7-pcie-attach/work_fseries-dk_flat/ofs-common/src/fpga_family/agilex/hps/hps_ss.qsys --synthesis=VERILOG --output-directory=/home/admin/SmartNIC/Intel/Intel-agilex/OFS_BUILD_ROOT/ofs-agx7-pcie-attach/work_fseri
Could you help clarify some basic questions first to help me understand better on the case
1) Just to confirm, does the cpu I7-14700 is the non K or the K version (eg. I7-14700k unlocked)
2) Does the issue always stalled at the same place (eg qsys-generate HDL design files for synthesis) or random? If you have other logs, please do provide them as well.
3) After the issue happened, like leaving the build for sometime, and then if you try to terminate the build (eg ctrl+c) , does the system still responding to commands etc. (just to make sure the system is still working)
4) Is there any specific OFS version that you need? eg 2023.3 or could you use the latest OFS (https://ofs.github.io/ofs-2024.2-1/hw/ftile_devkit/dev_guides/fim_dev/ug_ofs_ftile_dk_fim_dev/) , assuming you have the relevant Quartus version as well.
Meanwhile, I've an ubuntu 22.04 system with me, and will try out on the guide as well , do bear with me as it will take some time to compile the FIM and I will try to duplicate the issue on my end using the same version.
Kian
Hi Kian,
Thanks for your reply.
1) The CPU I7-14700 is the non-K version.
2) Yes, the issue always occurs in the same place during every compilation.
3) When the compilation is going on the CPU and RAM Utilization are at peak, causing the PC to hang. When the issue arises after some time, the CPU starts to idle and memory usage return to normal, After that I am able to terminate the process (Ctl+C).
4) No need of any specific OFS version, I went ahead with the 23.3 version because I had the Quartus 23.3 version in my System and also I had back in February of 2024 compiled the OFS version 23.3 once. If this is an issue with the OFS version I can install the latest Quartus 24 and follow the OFS version and try it out once. Will install the same and get back to you on this.
Thanks & Regards
Raizz
