Issue compiling code with volatile 3D array in loop
The following code seems to compile incorrectly in Intel i++ Lite 18.1 when targeting Cyclone V.
#include "HLS/hls.h" static volatile int32_t a[9][1][7]; component int result() { int tmp = 1; for (int b = 0; b != 2; b++) { a[0][0][0] = 3; a[0][0][0] = a[0][0][0]; } for (int i = 0; i < 9; i++) for (int k = 0; k < 7; k++) tmp ^= a[i][0][k]; return tmp; } int main() { printf("%X\n", result()); }
The code above prints 0 when compiled with i++, however, it should return 2. When compiling with the following command to generate the Verilog and simulating the design with Modelsim, intel i++ will return 0.
i++ test_Mod.cpp -v -march=CycloneV -o test-fpga
However, when compiling for x86 using the same command, the result is 2.
i++ test_Mod.cpp -march=x86-64 -o test-x86-64
This doesn't seem to occur with the i++ version that ships with the full version of Quartus, however, it might be because this i++ version somehow seems to unroll loops automatically (and incorrectly), whereas the full version of i++ doesn't seem to unroll the loops.
I noticed this because I get the following warnings:
Compiler Warning: Auto-unrolled loop at /home/ymherklotz/projects/hls_fuzzing/intel/intel/test_Mod.cpp:12 Compiler Warning: Auto-unrolled loop at /home/ymherklotz/projects/hls_fuzzing/intel/intel/test_Mod.cpp:7
1 Reply
- AnilErinch_A_Intel
Hi ,
You can prevent loop automatic loop unrolling using #pragma unroll 0 and get he code working as expected.
Thanks and Regards
Anil
