caron
7 years agoIntel FPGA SDK for OpenCL : how to generate an aocx file by the output of the OpenCL parser?
I want to modifying the Verilog code in the output of the OpenCL parser. Which is generated by the command "aoc -c -g device/vector_add.cl". And then I want to generate .aocx file from the folder. ...
FawazJ_Altera
7 years agoHello,
You can do that, however, this might change the functionality of the design. Furthermore, it might bring some timing issues which will increase the design complexity.
