RubenPadial
Contributor
1 year agoIntel FPGA AI Sutie Inference Engine
Is there any official documentation on the DLA runtime or inference engine for managing the DLA from the ARM side? I need to develop a custom application for running inference, but so far, I’ve only ...
JohnT_Altera
1 year agoHi Ruben,
I check on the log provided but it does not provide the full information on how you run it. Is it running the same graph? Or can you provide the step you use to run the application?
RubenPadial
Contributor
1 year agoHello @JohnT_Intel ,
Same grpah with nireq and niter set to 1 in every inference.
This is how I run the application:
./ris_app \
-arch_file=$arch \
-cm=$model \
-plugins_xml_file=$plugins \
-nireq=1 \
-niter=1 \
-d=HETERO:FPGA,CPU
As far as I know, I only used the graph once to configure the DLA, and then I continually request inferences to that instance. At least that was the objective.
