RubenPadial
Contributor
2 years agoIntel FPGA AI suite input data type
Hello, I'm using Intel FPGA AI 2023.2 on ubuntu 20.04 host computer and trying to infer a custom CNN in a Intel Arria 10 SoC FPGA. I have followed Intel FPGA AI Suite SoC Design Example Guide and...
RubenPadial
Contributor
2 years agoHello @JohnT_Intel ,
You can review the Model Optimizer help by using the command mo --help or consult to the OpenVINO documentation https://docs.openvino.ai/2023.2/notebooks/121-convert-to-openvino-with-output.html
Do you believe there is a significant difference between the options I'm employing and the guide you are refering to? In the guide, I observe that only the --input_model or --saved_model_dir options are specified, along with the --input_shape and --input/--output options for pruning non-supported layers. Notably, the --use_new_frontend option is not explicitly mentioned, and as I previously detailed, without its use, the input is identified as U8 instead of FP32.
