Intel FPGA AI Suite Inference Engine
I observed that the file provided does not support certain layer on FPGA side. This will cause the you to pass between FPGA and CPU.
I have check on the file you provided, it looks there is multiple layer that is not supported by FPGA.
Layer (Name: StatefulPartitionedCall/model/dense_1/BiasAdd, Type: Eltwise) is not supported: FPGA plugin: all parent nodes are not supported by FPGA.
Layer (Name: Constant_2560, Type: Constant) is not supported:
Layer (Name: StatefulPartitionedCall/model/dense_1/Tensordot, Type: Reshape) is not supported:
FPGA plugin: layer is not executed on FPGA because it does not have preceding layer on FPGA.
Layer (Name: StatefulPartitionedCall/model/dense_1/Tensordot/MatMul, Type: FullyConnected) is not supported:
FPGA plugin: this Fully Connected layer does not have preceding convolutional layer / sequence.
Layer (Name: StatefulPartitionedCall/model/re_lu_7/Relu, Type: Relu) is not supported:
Layer (Name: StatefulPartitionedCall/model/dense/BiasAdd, Type: Eltwise) is not supported:
FPGA plugin: 'Constant' nodes are not supported as input of nodes Eltwise
Layer (Name: Constant_2559, Type: Constant) is not supported:
