Intel FPGA AI Suite Inference Engine
Can you provide me the guide on how you generate the FPGA bitstream? Can you also share the input file so that I can duplicate the issue from my side?
- RubenPadial2 years ago
Contributor
Hi @JohnT_Intel
There is no custom bitstream. The bitstream was compiled following the instructions in the Intel FPGA AI Suite SoC Design Example Guide, specifically in section "3.3.2 Building the FPGA Bitstreams." The compilation was performed using the dla_build_example_design.py script with the following parameters:
dla_build_example_design.py \
-ed 4_A10_S2M \
-n 1 \
-a
$COREDLA_ROOT/example_architectures/A10_Performance.arch \
--build \
--build-dir
$COREDLA_WORK/a10_perf_bitstream \
--output-dir $COREDLA_WORK/a10_perf_bitstreamWhich input do you need? The TF model, the IR model, the compiled graph, input data...?
