RubenPadial
Contributor
3 years agoIntel FPGA AI Suite Inference Engine
Hello, I'm using Intel FPGA AI 2023.2 on ubuntu 20.04 host computer and trying to infer a custom CNN in a Intel Arria 10 SoC FPGA. I have followed Intel FPGA AI Suite SoC Design Example Guide and I...
JohnT_Altera
2 years agoHi,
Once you have completed the flow in https://www.intel.com/content/www/us/en/docs/programmable/777190/current/example-1-customized-resnet-18-model.html then you can use the generate IR file on OpenVINO. It will be performing as how you run the example design.
RubenPadial
Contributor
2 years agoHello,
IR and compiled graph were succesfully obtained. The question is how to run the model. In the example S2M image_streaming_app and streaming_inference_app are executed. The problems are:
- The input date must be in 224x224x3 BGR .bmp format, while my NN input data is 3 channel float data array. The NN was trained in this way and IR and graph was get accordingly. I can convert the data to bmp by my input size is 3360x360x3. I can change width and height with image_streaming_app flags but I don't know if it works because the input buffer.
- The output is comparted directly with "/app/categories.txt" file and the top 5 scores are given in result.txt. My output is completely different. I have 225 outputs. How can I get the gross output?
The other example, M2M example uses dla_benchmark app. And the problem is the same, how to change the input or how to use it with different input size and how to read the output
