RubenPadial
Contributor
2 years agoIntel FPGA AI suite accuracy drop
Hello, I'm using Intel FPGA AI 2023.2 on ubuntu 20.04 host computer and trying to infer a custom CNN in a Intel Arria 10 SoC FPGA. The CNN was trained with TensorFlow and the accuracy is 98.89% acr...
JohnT_Altera
2 years agoHi,
I suspect that the provided architecture might not be able to fully fit your needs. If you need to have a better performance then customizing into new architecture will better benefit your requirement. Unless the DLA you plan to run is the same as what has been tested by Intel.
