Intel BD-NVV-N3000-2 issue
I am unable to get converger cable part number from cable vendor.
Just to double check, you could have referred data sheet snapshot of power requirement. Power should be given from both 12V port on motherboard correct?
Hi Jonway,
We have observed after booting into OS the led status of 1,2,4 port is blinking yellow and 3rd is blinking green on card. Can you please confirm Intel LWF2208IR514206 server is compatible with Intel BD-NVV-N3000-2 FPGA card. Yet we haven't got any solution, please help to resolve this issue.
- samir_bhansali6 years ago
Server Prod Code : Intel LWF2208IR848505
Motherboard Model : S2600WF
CPU : Intel Xeon Gold 6248
Slot : PCIe x16
Aux Cable : H38461-001
- JonWay_altera6 years ago
The LED blinking combination you mentioned is not logical. Attaching the screenshot of the LED (you can find this info in the datasheet too), I would expect that since you are using BD-NVV-N3000-2, this is a 25bE card. Thus, connectivity LED should be GREEN when you connected the cable to an active link partner. I am not expecting any yellow (which is for 10Gb). Can you specify which is LED 1,2,3,4 based on the screenshot provided?
Did you reimage the FPGA to a 10Gb?
Could you paste the output for "fpgainfo fme" "fpgainfo phy" "fpgainfo port" "fpgainfo bmc" here?
Can you try a different card?
Hi Jonway,
As per attached snapshot, counting led from left to right. So the 1,2,4 is showing blinking yellow and 3 is blinking green. This is 25GbE card and there are no QSFP cables connected. We have installed each card in 2 servers and both are not detecting in OS.
Kindly find attached command output.
Hi, I have sent you a private message.
Hi Jonway,
I have tried same FPGA card in Supermicro 7049GP-TRT server and observed FPGA is not detecting. Please find attached "lspci" command output.
HI Jonway,
Have you any solution on this.
1) If you suspect, it is a card issue, can you try with a different card?
2) If it is the same on all cards, can you let me know if lspci not detect card happens immediately right after boot up
OR
it was detected at first but failed later on?
Also, is the LED at blinking at 1 sec interval. If yes, happens immediately right after boot up or failed later on?
Hi Jonway,
I have checked again Intel FPGA card with Supermicro SYS-7049GP-TRT server and found, after powering on the server there is no led glowing on FPGA led. After booting to OS led blinking status is 1,3 blinking green and 2,4 blinking yellow.
Immediately after booting to OS and also later on, we tried with "lspci" command and now the card is showing in output list.
Please find attached output for your reference.
Kindly check attachment and let us know whether card is detecting properly or not.
Please suggest what could be the issue with Intel server for FPGA card detection.
Based on the supermicro lspci output, it shows the card is detected properly.
60:00.0 Ethernet controller: Intel Corporation Ethernet Controller XXV710 Intel(R) FPGA Programmable Acceleration Card N3000 for Networking (rev 02)
60:00.1 Ethernet controller: Intel Corporation Ethernet Controller XXV710 Intel(R) FPGA Programmable Acceleration Card N3000 for Networking (rev 02)
61:00.0 Processing accelerators: Intel Corporation Device 0b30
62:00.0 Ethernet controller: Intel Corporation Ethernet Controller XXV710 Intel(R) FPGA Programmable Acceleration Card N3000 for Networking (rev 02)
62:00.1 Ethernet controller: Intel Corporation Ethernet Controller XXV710 Intel(R) FPGA Programmable Acceleration Card N3000 for Networking (rev 02)
63:00.0 Processing accelerators: Intel Corporation Device 0b32 - JonWay_altera6 years ago
Given that the Supermicro works and the Wolfpass server does not. It is most probably that you need the Airduct recommended by the server, which should be used with the card: https://ark.intel.com/content/www/us/en/ark/products/125929/passive-airduct-kit-awfcoproductad.html
Hi Jonway,
Below suggested accessories is already installed in Intel LWF2208IR848505 server.
Accessory: AWFCOPRODUCTBKT: High Air flow Air Duct Bracket Kit & A2UL16RISER2: 2-slot PCIe* Riser card.
Please suggest else what could be the issue in intel server.
1. Confirm that you are running at maximum fan speed
2. Does the card shutdown even at idling? if no, you may want to check with your workload developer how to reduce the workload.
Hi Jonway,
Fans are running on normal mode.
Yes server is in idle mode.
Hi Jonway,
Below is the attached output from supermicro server when immediately run the command after booted to OS for your reference.
But after OS booted later on the output is different.
I think this further confirmed that you dont have enough airflow.
When you first booted into OS, the card is still working but very near to shutdown temperature.
(12) FPGA Die Temperature : 96.50 Celsius
After a while, when the temperature exceed 100C, it will shutdown, and you wont get any reading.
The card is fine and working as expected. The problem is that you dont have enough airflow to the card. You will need to check with the server vendor on how to improve airflow to the pcie slots devices.
- ahaa5 years ago
some questions:
1. how to confirm that you are running at maximum fan speed or modify it?
2. the fan referred to here is the fan of pac board or the fan or server machine?
thanks very much
- JonWay_altera5 years ago
hi @ahaa
There is no fan on the pac card. It is passively cooled.
Some server vendors fan speed is changed in the BIOS and some are changed via the server BMC (maybe there are more other ways), you will need to check with the server vendor to know what speed you are running at, and how to change it.
