How to Reconfigure and make changes in Quartus for a built and compiled OFS FIM.
Sorry for the delay in response. Regarding your question , the document to compile FIM is solely based on command line terminal and if I understand correctly, most of the script/shell in there handles the linking of different components to the Quartus project and there is no standalone Quartus project can be built out without those command line scripts even though it exist in the git directory.
May I confirm if I get you right, you have successfully build out the FIM and you open the Quartus project that was generated out in the output folder or from the default directory?
For the PR directory, its mainly used to share your FIM settings with others who wants to do their own AFU configuration, but it still needs to be executed via script
eg. if user just want to use the default fim, he/she will just download the prebuilt FIM from here and run their own AFU from there. It looks like still need to run through script though.
Reference:
KH
