How can I use my transitional windows based FPGA design flow experience into OPAE design flow
1,During the processing I can open the QUARTUS prime GUI with opening the dcp.qsf, Does this project include AFU and FME,FIU,FME all modules?because I can't find these static module from logiclock window and design partition window. In the traditional partial reconfigration design flow ,we can see all design partitions in above 2 windows.
Unfortunately no. You are not able to view it as the static region design has been encrypted.
2,Can I do syntheses and place and routing in GUI ? I found quartus GUI report error if I do place and routing. because once GUI lunched, click start is always easier than tcl command.
No. It is recommended to use command mode to compile it as it need to run its own flow.
3, Can intel PAC card support traditional design flow if I do not need CPU do anything for time being? If so , any resource I can have? I found there is no schematic and FPGA Pinout document at all from website, where can I get these document?
No., it is not supported.
