How can I port RTL module into oneAPI FPGA programming ?
Hi there, I have been using oneAPI for FPGA programming for a while. I am now trying to port my well-defined RTL module into my oneAPI implementation.
I do read and understand the specification documents provided in oneAPI websites also the openCL SDK development. However, one of these have pointed a very clear way to interact with RTL module using oneAPI.
I am successfully runing a combinational vector-add sample myself, but have no idea how to interact with the sythesized modules from oneAPI with clock driven capability and Avalon-ST interface.
Have anyone done such a tryout before ?
Best.
- hareesh
- hareesh
any update about your issue?
- maxhu
Hi hareesh,
Sorry for late reply. I have solved the problem that I encountered. The real question thta I want to ask is that, is there a way to illustrate the implementation of Avalon-Stream interface under backpressure modules ? Although I have solved the problem, I am still confused about the Avalon-Stream interface specified by the Intel OpenCL SDK website.
I do read some examples about OpenCL SDK programming, one for simple combinational circuit and another one for a very complicated extern memory interaction example. The true is that, combinational is too simple but interacting with external memory is too much complicated. Is there a mid-point example that I can explore ?
Best,
Jiajun.
- hareesh
I shared the working design. please go through it.
- hareesh
i will check and will update to you
- maxhu
Hi Hareesh,
Did you get anything back from your colleagues ? I tried implemented a simple Avalon Stream interface based on the oneAPI documents and also the given example. I modified the original combinational logic example into a sequential version. However, I still lack some more details:
1. I dont konw the exact specification of the required Avalon-Stream interface for porting RTL into oneAPI environment. Is there any worked example or detailed illustration that I can check ?
2. I am able to get the simulation waveform using ModelSim, however, I cannot read the Machine Generated signals... Is there any more convinient way to debug my RTL module ?
3. To my understanding and based on the given documents from oneAPI websites, I wrote the RTL code for porting a simple vector add RTL module into oneAPI, which may not meet the requirements of Avalon Stream interface. The code and XML file are attached below.
`timescale 1 ps / 1 ps module lib_rtl ( input clock, input resetn, input ivalid, input iready, output ovalid, output oready, input [31:0] datain1, input [31:0] datain2, output [31:0] dataout); logic [31:0] dataout_buffer, dataout_reg; logic ovalid_reg, oready_reg; assign ovalid = ovalid_reg; assign oready = oready_reg; assign dataout = (oready_reg & !iready) ? dataout_buffer : dataout_reg; // assign dataout = result; // clock, ivalid, iready, resetn are ignored always @(posedge clock) begin // reset or non-valid input // all the signals are default zero if(!resetn || !ivalid) begin dataout_reg <= 0; dataout_buffer <= 0; oready_reg <= 0; ovalid_reg <= 0; end else if (ivalid) begin ovalid_reg <= 1; oready_reg <= 1; dataout_reg <= datain1 + datain2; end end always@(*) begin $display("ivalid = %d iready = %d dataout_reg = %d\n", ivalid, iready, dataout_reg); $display("datain1 = %d data2 = %d dataout %d\n", datain1, datain1, dataout); end endmodule<RTL_SPEC> <FUNCTION name="RtlByteswap" module="lib_rtl"> <ATTRIBUTES> <IS_STALL_FREE value="yes"/> <IS_FIXED_LATENCY value="yes"/> <EXPECTED_LATENCY value="0"/> <CAPACITY value="0"/> <HAS_SIDE_EFFECTS value="no"/> <ALLOW_MERGING value="yes"/> </ATTRIBUTES> <INTERFACE> <AVALON port="clock" type="clock"/> <AVALON port="resetn" type="resetn"/> <AVALON port="ivalid" type="ivalid"/> <AVALON port="iready" type="iready"/> <AVALON port="ovalid" type="ovalid"/> <AVALON port="oready" type="oready"/> <INPUT port="datain1" width="32"/> <INPUT port="datain2" width="32"/> <OUTPUT port="dataout" width="32"/> </INTERFACE> <REQUIREMENTS> <FILE name="lib_rtl.v" /> </REQUIREMENTS> </FUNCTION> </RTL_SPEC>I also read some materials from Intel OpenCL SDK for FPGA docs, there are some documents telling how to mix RTL and OpenCL together, but I am not sure whether they are accurate reference docs. Please give me more details for further exploration.
Thanks for your kind reply and help.
Best,
Jiajun.
