ybrstud
6 years agoHLS Main Optimizer Failed: The command line is too long
Hello everybody, currently I am working on a project, where I want to use the HLS compiler to use my c++ code on the FPGA. To your information: FPGA is CycloneV, Quartus version is 18.1 lite. Every ...
MEIYAN_L_Intel
6 years agoHi,
It might be the design code problem. Could you provide the design code for further investigate?
ybrstud
6 years agoHi,
is it possbile to you to check where the issue in the commit below has its origin?
Maybe it is the same problem, because in the examples there should be no design code error.
Thanks and best regards
