HardSigmoid and Intel FPGA AI suite
It will depends on which FPGA bitstream that you are using. I suspect that the precompiled bitstream that you are using does not support H-Sigmoid.
Hello @JohnT_Intel,
I tried to compile the graph with several architectures from $COREDLA_ROOT/example_architectures/, but I get the same result. I attempted using A10/S10/AGX7_Generic/Performance.arch architecture files, and in none of them, H-Sigmoid is implemented in the FPGA. The "Intel FPGA AI Suite SoC Design Example User Guide" requires graph compilation with A10_performance.arch. It is understood that the bitstream must be compiled with that architecture file. However, I can't find any information in Intel's documentation regarding layer-architecture dependencies. In Intel FPGA AI Suite: IP Reference Manual Chapter 2.3, all the compatible layers are listed, but the architectures are not specified. That's why I'm asking; according to Intel documentation, the H-Sigmoid layer should be supported. could you confirm it?
