HardSigmoid and Intel FPGA AI suite
The H-Sigmoid should be possible if you are compiling the FPGA design. Can you confirm if you have AI Suite license? If no then you might have limited model that you can test it out..
Hi @JohnT_Intel
Do you mean that the compiling and performance estimation process is different when using the Intel FPGA AI Suite compared to not using it?
Based on the information provided in the "Intel FPGA AI Suite: Getting Started Guide" and the "Intel FPGA AI Suite SoC Design Example User Guide," I understand that a license is needed to build the Intel FPGA AI Suite core IP bitstream, but compiling the graph does not require a license.
To test my own model without a license, can I compile it with the "A10_Performance.arch" files, as demonstrated in the examples, and test it with the prebuilt SD card image?
