Getting "HAL Kern Error: Read/Write failed from addr x, read y expected z" when running multithread OpenCL application on CycloneV SoC
Hi are you using a custom made board for running the openCL.
In that case please use the following api in the code aocl_mmd_get_info
and let us know the results.
In particular we would be interested in results with following
AOCL_MMD_BOARD_NAME
AOCL_MMD_CONCURRENT_READS Number of parallel reads( A value of 1 indicates serial reads.)
AOCL_MMD_CONCURRENT_WRITES Number of parallel writes (A value of 1 indicates serial writes).
AOCL_MMD_CONCURRENT_READS_OR_WRITE S Total number of concurrent read and write operations .
Please refer here
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/ug_aocl_custom_platform_toolkit.pdf
- jackgreen5 years ago
Hi I am having a similar problem on the de10 nano board. After checking the corresponding source code, I found out that the MMD library is of version 14.1 and it does not have AOCL_MMD_CONCURRENT_READS and AOCL_MMD_CONCURRENT_WRITES defined. So I guess it might be the problem? And how shall we update this library? Is there any off-the-shelf code I could take advantage of?
Thanks!
