JButt5
7 years agoGetting a lot of "HAL Kern Error: Read failed from addr x, read y expected z" errors – what to do?
I compiled an application that works flawlessly on a GPU based system for a Cyclone V SoC today. It contains 3 CL Kernels, two of them are single-work-item kernels, one is an ND-Range kernel. Two com...
- 7 years ago
It seem like the problem is from the custom BSP.
You may need to refer to the custom platfrom user guide with the link as below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/ug_aocl_custom_platform_toolkit.pdf
TSchw11
6 years agoTo ensure, that the error is not caused by a version incompatibility, I just compiled both the host application and the aocx file (of the opencl_multithread_vector_operation example) using the 18.0 version of the Intel SDK. That version is matching the version of the supplied BSP.
The error still occurs, so it doesn't seem to be a version incompatibility.
