JButt5
7 years agoGetting a lot of "HAL Kern Error: Read failed from addr x, read y expected z" errors – what to do?
I compiled an application that works flawlessly on a GPU based system for a Cyclone V SoC today. It contains 3 CL Kernels, two of them are single-work-item kernels, one is an ND-Range kernel. Two com...
- 7 years ago
It seem like the problem is from the custom BSP.
You may need to refer to the custom platfrom user guide with the link as below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/ug_aocl_custom_platform_toolkit.pdf
MEIYAN_L_Intel
6 years agoHi,
From your question, I saw you are using the design example "multithread vector" example, am I right?
May I know other example like hello_world and vector_add can be compile successfully?
Are you building the BSP in other version and porting the BSP to 18.1 version?
Could you try to looking into the version for MMD?
