JButt5
7 years agoGetting a lot of "HAL Kern Error: Read failed from addr x, read y expected z" errors – what to do?
I compiled an application that works flawlessly on a GPU based system for a Cyclone V SoC today. It contains 3 CL Kernels, two of them are single-work-item kernels, one is an ND-Range kernel. Two com...
- 7 years ago
It seem like the problem is from the custom BSP.
You may need to refer to the custom platfrom user guide with the link as below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/ug_aocl_custom_platform_toolkit.pdf
JButt5
7 years agoThank you, this looks like a great resource to get some in-depth knowledge I had not found before. All my previous BSP knowledge was based mostly on studying the implementation of existing platforms and some papers roughly explaining a workflow. However I'd still be thankful in case someone maybe some of the runtime developers are round here and could say what kind of error leads to messages like that 😊
