PGorl1
7 years ago[FPGA SDK for OpenCL] External IO channel problem.
System integrator fails when the data type size of the external IO channel is different from 256b. You can reproduce the error using the attached code. $ make trigger_bug
aoc -v -v -v -D__TRIGGER...
PGorl1
7 years agoYes, the Bittware customer support team affirms that this problem is caused by the HLS tool.
HRZ
7 years agoI see. Then it would probably be faster if they directly raise the issue with Intel through their direct channels, rather than going through the forums.
