PGorl1
7 years ago[FPGA SDK for OpenCL] External IO channel problem.
System integrator fails when the data type size of the external IO channel is different from 256b. You can reproduce the error using the attached code. $ make trigger_bug
aoc -v -v -v -D__TRIGGER...
HRZ
7 years agoHave you confirmed with Nallatech that this is not a BSP issue? It is very much possible they did not include the necessary logic in their BSP for the 520N board to convert the channel read/write width if the logical width and physical width do not match.
- PGorl17 years ago
Yes, the Bittware customer support team affirms that this problem is caused by the HLS tool.
