FL's avatar
FL
6 years ago
FIM and BMC Firmware not available on Acceleration Board A10
I was installing OPAE on host machine, my PC, for Intel Programmable Acceleration Card with Intel Arria 10 GX FPGA and encounted the attached problem when ruuning the following command $ sudo fpga...
  • JohnT_Altera's avatar
    6 years ago
    Since your PAC card is from 1.0Beta version, you will need to update it to 1.1 version before proceeding to 1.2.
    So you will need to update the board to 1.1 PV before updating to 1.2 PV. Sorry for the inconvenience.
    Follow the "Identifying and Updating FIM" section of the 1.1PV version of the Intel Acceleration Stack Quick Start Guide for Intel Programmable Acceleration Card with Intel Arria 10 GX FPGA to first update to 1.1PV FIM (dcp_1_1.rpd).
    Note: • It is acceptable to leverage the 1.2 OPAE packages when following the FIM update instructions from the 1.1PV version of the Intel Acceleration Stack Quick Start Guide for Intel Programmable Acceleration Card with Intel Arria 10 GX FPGA.
    • 1.1PV runtime download package can be located here. For access to the previous version of the Intel Acceleration Stack Quick Start Guide for Intel Programmable Acceleration Card with Intel Arria 10 GX FPGA, refer to the "Intel Acceleration Stack Quick Start Guide for Intel Programmable Acceleration Card with Intel Arria 10 GX FPGA Archives" section.
    2. Follow the instructions in the "Updating FPGA Flash and BMC Firmware" section in the current version of this document
