FIM and BMC Firmware not available on Acceleration Board A10
- 6 years ago
Since your PAC card is from 1.0Beta version, you will need to update it to 1.1 version before proceeding to 1.2.
So you will need to update the board to 1.1 PV before updating to 1.2 PV. Sorry for the inconvenience.
Follow the "Identifying and Updating FIM" section of the 1.1PV version of the Intel Acceleration Stack Quick Start Guide for Intel Programmable Acceleration Card with Intel Arria 10 GX FPGA to first update to 1.1PV FIM (dcp_1_1.rpd).
Note: • It is acceptable to leverage the 1.2 OPAE packages when following the FIM update instructions from the 1.1PV version of the Intel Acceleration Stack Quick Start Guide for Intel Programmable Acceleration Card with Intel Arria 10 GX FPGA.
• 1.1PV runtime download package can be located here. For access to the previous version of the Intel Acceleration Stack Quick Start Guide for Intel Programmable Acceleration Card with Intel Arria 10 GX FPGA, refer to the "Intel Acceleration Stack Quick Start Guide for Intel Programmable Acceleration Card with Intel Arria 10 GX FPGA Archives" section.
2. Follow the instructions in the "Updating FPGA Flash and BMC Firmware" section in the current version of this document
May I know which acceleration stack version are you using for your installation? The board that you are using is from Acceleration Stack 1.1. So if you are using Acceleration Stack 1.2 or 1.2.1 then I would recommend you to update your board to the Acceleration Stack software you are using before moving forward.
- FL6 years ago
Right, I guess I used the 1.1 version of acceleration stack but I directly download from here
which I thought it could be installed as 1.2.1 version. Then I found the upgrade page here
Is it right for updating the FIM and BMC version?
Thanks!
- FL6 years ago
Hi, now I have a new issue during updating process:
It always stops here when I run setup.sh even after I install this package dependency.
