Failure to fit an Arria 10 design through insufficent LABs when no problem in reports
- 5 years ago
Hi
With insight from an Intel FPGA expert I have now solved this issue. The problem is that the reports are misreporting the percentage of MLABs that the design is using. The compiler error message is correctly indicating that I am asking for too many MLABs whereas the corresponding Area Analysis report is saying I am using only 65% of them.
My solution is to check my MLAB use against the known MLAB capacity of the FPGA rather than trust the report.
Marcus
Hi @Mickleman,
Thank you for posting and sharing the solution in Intel community forum and hope all is well.
With no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread.
Thanks for your questions and as always pleasure having you here.
Best Wishes
BB
