Error when compiling for Stratix USM
Hi all,
Thanks for this space. I'm having a problem since 2 months that I cant resolve. I have a simple code that uses USM and I want to compile it for FPGAs in the Devcloud. As I know, only Stratix has the USM feature (Arria don't). So, I use this commands:
qsub -l nodes=1:fpga_compile:ppn=2 -I source /opt/intel/oneapi/setvars.sh icpx -fsycl -fintelfpga -Xshardware -Xstarget=/opt/intel/oneapi/intel_s10sx_pac:pac_s10_usm test.cpp -o test -v
The error I'm getting is:
Error (23035): Tcl error: Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings For more details, full Quartus compile output can be found in files quartuserr.tmp and quartus_sh_compile.log. Error: Compiler Error, not able to generate hardware.
the quartus log says:
This is the PAC OpenCL BSP run.sh script. Compiling import revision flow... ERROR: packager check failed with output '' Info: ******************************************************************* Info: Running Quartus Prime Shell Info: Version 19.2.0 Build 57 06/24/2019 Patches 0.05dcp SJ Pro Edition Info: Copyright (C) 2019 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and any partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details, at Info: https://fpgasoftware.intel.com/eula. Info: Processing started: Thu Mar 23 14:08:08 2023 Info: Command: quartus_sh -t build/entry.tcl import Info: Quartus(args): import Info: Using INI file /tmp/test-f3f56b-e5d1ff/quartus.ini Info: Compiling revision import Error (23035): Tcl error: while executing "qexec "bash build/run.sh $revision_name"" ("default" arm line 9) invoked from within "switch $tcl_platform(platform) { windows { post_message -type error "Full compiles to generate hardware for the FPGA are available on supported ..." (file "build/entry.tcl" line 19) Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings Error: Peak virtual memory: 979 megabytes Error: Processing ended: Thu Mar 23 14:08:09 2023 Error: Elapsed time: 00:00:01
Can you help me with this? Can anyone compile for Stratix USM and then execute it? Thank you very much.
Here is the code:
#include <sycl/sycl.hpp> #include <array> #include <iostream> #include <string> using namespace sycl; size_t array_size = 10000; //************************************ // Vector add in SYCL on device: returns sum in 4th parameter "sum". //************************************ void VectorAdd(queue &q, const int *a, const int *b, int *sum, size_t size) { // Create the range object for the arrays. range<1> num_items{size}; auto e = q.parallel_for(num_items, [=](auto i) { sum[i] = a[i] + b[i]; }); e.wait(); } //************************************ // Initialize the array from 0 to array_size - 1 //************************************ void InitializeArray(int *a, size_t size) { for (size_t i = 0; i < size; i++) a[i] = i; } int main(int argc, char *argv[]) { try { sycl::queue q((sycl::device::get_devices()[std::stoi(argv[1])])); // Print out the device information used for the kernel code. std::cout << "Running on device: " << q.get_device().get_info<info::device::name>() << "\n"; std::cout << "Running on device: " << q.get_device().get_info<info::device::max_compute_units>() << "\n"; std::cout << "Running on device: " << q.get_device().get_info<info::device::max_work_group_size>() << "\n"; std::cout << "Running on device: " << q.get_device().get_info<info::device::global_mem_size>() << "\n"; int *a = malloc_shared<int>(array_size, q); int *b = malloc_shared<int>(array_size, q); int *sum_sequential = malloc_shared<int>(array_size, q); int *sum_parallel = malloc_shared<int>(array_size, q); if ((a == nullptr) || (b == nullptr) || (sum_sequential == nullptr) || (sum_parallel == nullptr)) { if (a != nullptr) free(a, q); if (b != nullptr) free(b, q); if (sum_sequential != nullptr) free(sum_sequential, q); if (sum_parallel != nullptr) free(sum_parallel, q); std::cout << "Shared memory allocation failure.\n"; return -1; } InitializeArray(a, array_size); InitializeArray(b, array_size); for (size_t i = 0; i < array_size; i++) sum_sequential[i] = a[i] + b[i]; VectorAdd(q, a, b, sum_parallel, array_size); for (size_t i = 0; i < array_size; i++) { if (sum_parallel[i] != sum_sequential[i]) { std::cout << "Vector add failed on device.\n"; return -1; } } int indices[]{0, 1, 2, (static_cast<int>(array_size) - 1)}; constexpr size_t indices_size = sizeof(indices) / sizeof(int); for (int i = 0; i < indices_size; i++) { int j = indices[i]; if (i == indices_size - 1) std::cout << "...\n"; std::cout << "[" << j << "]: " << j << " + " << j << " = " << sum_sequential[j] << "\n"; } free(a, q); free(b, q); free(sum_sequential, q); free(sum_parallel, q); } catch (exception const &e) { std::cout << "An exception is caught while adding two vectors.\n"; std::terminate(); } std::cout << "Vector add successfully completed on device.\n"; return 0; }
- hareesh
thank you for posting your issue here. please give me some I am working on this.
Thank you,
- ManuelCostanzo2
@hareesh Thank you very much
- hareesh
can you please share your log file and tcl script file
- ManuelCostanzo2
Hi @hareesh, yes. Could you reproduce it?
u180336@s001-n061:~/test2$ icpx -fsycl -fintelfpga -Xshardware -Xstarget=/opt/intel/oneapi/intel_s10sx_pac:pac_s10_usm test.cpp -o test -v Intel(R) oneAPI DPC++/C++ Compiler 2023.0.0 (2023.0.0.20221201) Target: x86_64-unknown-linux-gnu Thread model: posix InstalledDir: /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm Configuration file: /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../bin/icpx.cfg Found candidate GCC installation: /usr/lib/gcc/x86_64-linux-gnu/9 Selected GCC installation: /usr/lib/gcc/x86_64-linux-gnu/9 Candidate multilib: .;@m64 Selected multilib: .;@m64 "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang++" -cc1 -triple spir64_fpga-unknown-unknown -aux-triple x86_64-unknown-linux-gnu -fsycl-is-device -fdeclare-spirv-builtins -fno-sycl-early-optimizations -fenable-sycl-dae -fsycl-instrument-device-code -Wno-sycl-strict -fsycl-int-header=/tmp/icpx-1bd1ca/test-header-1f9bcb.h -fsycl-int-footer=/tmp/icpx-1bd1ca/test-footer-3234d0.h -sycl-std=2020 -fsycl-unique-prefix=7851da85a9f613b7 -fsycl-disable-range-rounding -fintelfpga -Wspir-compat -emit-llvm-bc -emit-llvm-uselists -disable-free -clear-ast-before-backend -disable-llvm-verifier -main-file-name test.cpp -mrelocation-model static -fveclib=SVML -mframe-pointer=all -menable-no-infs -menable-no-nans -fapprox-func -menable-unsafe-fp-math -fno-signed-zeros -mreassociate -freciprocal-math -fdenormal-fp-math=preserve-sign,preserve-sign -ffp-contract=fast -fno-rounding-math -ffast-math -ffinite-math-only -fno-verbose-asm -mconstructor-aliases -aux-target-cpu x86-64 -mllvm -treat-scalable-fixed-error-as-warning -debug-info-kind=limited -dwarf-version=4 -debugger-tuning=gdb -v -resource-dir /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/lib/clang/16.0.0 -dependency-file /tmp/icpx-1bd1ca/test-efa644.d -MT test.o -internal-isystem /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl -internal-isystem /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/vpl/2023.0.0/include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/tbb/2021.8.0/env/../include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/mpi/2021.8.0//include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/mkl/2023.0.0/include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/ipp/2021.7.0/include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/ippcp/2021.6.3/include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/ipp/2021.7.0/include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/dpl/2022.0.0/linux/include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/dpcpp-ct/2023.0.0/include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/dnnl/2023.0.0/cpu_dpcpp_gpu_dpcpp/include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/dev-utilities/2021.8.0/include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/dal/2023.0.0/include -I/glob/development-tools/versions/oneapi/2023.0.1/oneapi/ccl/2021.8.0/include/cpu_gpu_dpcpp -cxx-isystem /glob/development-tools/versions/oneapi/2023.0.1/oneapi/clck/2021.7.2/include -internal-isystem /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../compiler/include -internal-isystem /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9 -internal-isystem /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/x86_64-linux-gnu/c++/9 -internal-isystem /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/backward -internal-isystem /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9 -internal-isystem /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/x86_64-linux-gnu/c++/9 -internal-isystem /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/backward -internal-isystem /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/lib/clang/16.0.0/include -internal-isystem /usr/local/include -internal-isystem /usr/lib/gcc/x86_64-linux-gnu/9/../../../../x86_64-linux-gnu/include -internal-externc-isystem /usr/include/x86_64-linux-gnu -internal-externc-isystem /include -internal-externc-isystem /usr/include -internal-isystem /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/lib/clang/16.0.0/include -internal-isystem /usr/local/include -internal-isystem /usr/lib/gcc/x86_64-linux-gnu/9/../../../../x86_64-linux-gnu/include -internal-externc-isystem /usr/include/x86_64-linux-gnu -internal-externc-isystem /include -internal-externc-isystem /usr/include -O2 -std=c++17 -fdeprecated-macro -fdebug-compilation-dir=/home/u180336/test2 -ferror-limit 19 -fheinous-gnu-extensions -fgnuc-version=4.2.1 -no-opaque-pointers -fcxx-exceptions -fexceptions -fcolor-diagnostics -vectorize-loops -vectorize-slp -dwarf-debug-flags " --driver-mode=g++ --intel -fintelfpga -Xshardware -Xstarget=/opt/intel/oneapi/intel_s10sx_pac:pac_s10_usm test.cpp -o test -v -g -O2 -fveclib=SVML -fheinous-gnu-extensions" -D__GCC_HAVE_DWARF2_CFI_ASM=1 -fintel-compatibility -fintel-compatibility-disable=FakeLoad -fintel-libirc-allowed -mllvm -disable-hir-generate-mkl-call -mllvm -intel-abi-compatible=true -o /tmp/icpx-1bd1ca/test-5abc20.bc -x c++ test.cpp clang -cc1 version 16.0.0 based upon LLVM 16.0.0git default target x86_64-unknown-linux-gnu ignoring nonexistent directory "/usr/lib/gcc/x86_64-linux-gnu/9/../../../../x86_64-linux-gnu/include" ignoring nonexistent directory "/include" ignoring nonexistent directory "/usr/lib/gcc/x86_64-linux-gnu/9/../../../../x86_64-linux-gnu/include" ignoring nonexistent directory "/include" ignoring duplicate directory "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/ipp/2021.7.0/include" ignoring duplicate directory "/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9" ignoring duplicate directory "/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/x86_64-linux-gnu/c++/9" ignoring duplicate directory "/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/backward" ignoring duplicate directory "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/lib/clang/16.0.0/include" ignoring duplicate directory "/usr/local/include" ignoring duplicate directory "/usr/include/x86_64-linux-gnu" ignoring duplicate directory "/usr/include" ignoring duplicate directory "/usr/local/include" ignoring duplicate directory "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/lib/clang/16.0.0/include" ignoring duplicate directory "/usr/include" #include "..." search starts here: #include <...> search starts here: /glob/development-tools/versions/oneapi/2023.0.1/oneapi/vpl/2023.0.0/include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/tbb/2021.8.0/env/../include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/mpi/2021.8.0//include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/mkl/2023.0.0/include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/ipp/2021.7.0/include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/ippcp/2021.6.3/include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/dpl/2022.0.0/linux/include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/dpcpp-ct/2023.0.0/include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/dnnl/2023.0.0/cpu_dpcpp_gpu_dpcpp/include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/dev-utilities/2021.8.0/include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/dal/2023.0.0/include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/ccl/2021.8.0/include/cpu_gpu_dpcpp /glob/development-tools/versions/oneapi/2023.0.1/oneapi/clck/2021.7.2/include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../include /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../compiler/include /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9 /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/x86_64-linux-gnu/c++/9 /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/backward /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/lib/clang/16.0.0/include /usr/local/include /usr/include/x86_64-linux-gnu /usr/include End of search list. "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/llvm-link" /tmp/icpx-1bd1ca/test-5abc20.bc -o /tmp/icpx-1bd1ca/test-03a166.bc --suppress-warnings "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-crt.o -output=/tmp/icpx-1bd1ca/libsycl-crt-875221.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-complex.o -output=/tmp/icpx-1bd1ca/libsycl-complex-d541a1.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-complex-fp64.o -output=/tmp/icpx-1bd1ca/libsycl-complex-fp64-1fbcce.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-cmath.o -output=/tmp/icpx-1bd1ca/libsycl-cmath-cad602.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-cmath-fp64.o -output=/tmp/icpx-1bd1ca/libsycl-cmath-fp64-b0552c.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-imf.o -output=/tmp/icpx-1bd1ca/libsycl-imf-ba30c6.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-imf-fp64.o -output=/tmp/icpx-1bd1ca/libsycl-imf-fp64-2ab6b5.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-fallback-cassert.o -output=/tmp/icpx-1bd1ca/libsycl-fallback-cassert-7c5391.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-fallback-cstring.o -output=/tmp/icpx-1bd1ca/libsycl-fallback-cstring-15becb.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-fallback-complex.o -output=/tmp/icpx-1bd1ca/libsycl-fallback-complex-07c6ce.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-fallback-complex-fp64.o -output=/tmp/icpx-1bd1ca/libsycl-fallback-complex-fp64-288585.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-fallback-cmath.o -output=/tmp/icpx-1bd1ca/libsycl-fallback-cmath-baf70a.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-fallback-cmath-fp64.o -output=/tmp/icpx-1bd1ca/libsycl-fallback-cmath-fp64-c861bf.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-fallback-imf.o -output=/tmp/icpx-1bd1ca/libsycl-fallback-imf-2c5da1.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-fallback-imf-fp64.o -output=/tmp/icpx-1bd1ca/libsycl-fallback-imf-fp64-9b8514.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-itt-user-wrappers.o -output=/tmp/icpx-1bd1ca/libsycl-itt-user-wrappers-33cb85.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-itt-compiler-wrappers.o -output=/tmp/icpx-1bd1ca/libsycl-itt-compiler-wrappers-04ffb0.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/clang-offload-bundler" -type=o -targets=sycl-spir64_fpga-unknown-unknown -input=/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/../lib/libsycl-itt-stubs.o -output=/tmp/icpx-1bd1ca/libsycl-itt-stubs-978093.o -unbundle -allow-missing-bundles -base-temp-dir=/tmp/icpx-1bd1ca "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/llvm-link" -only-needed /tmp/icpx-1bd1ca/test-03a166.bc /tmp/icpx-1bd1ca/libsycl-crt-875221.o /tmp/icpx-1bd1ca/libsycl-complex-d541a1.o /tmp/icpx-1bd1ca/libsycl-complex-fp64-1fbcce.o /tmp/icpx-1bd1ca/libsycl-cmath-cad602.o /tmp/icpx-1bd1ca/libsycl-cmath-fp64-b0552c.o /tmp/icpx-1bd1ca/libsycl-imf-ba30c6.o /tmp/icpx-1bd1ca/libsycl-imf-fp64-2ab6b5.o /tmp/icpx-1bd1ca/libsycl-fallback-cassert-7c5391.o /tmp/icpx-1bd1ca/libsycl-fallback-cstring-15becb.o /tmp/icpx-1bd1ca/libsycl-fallback-complex-07c6ce.o /tmp/icpx-1bd1ca/libsycl-fallback-complex-fp64-288585.o /tmp/icpx-1bd1ca/libsycl-fallback-cmath-baf70a.o /tmp/icpx-1bd1ca/libsycl-fallback-cmath-fp64-c861bf.o /tmp/icpx-1bd1ca/libsycl-fallback-imf-2c5da1.o /tmp/icpx-1bd1ca/libsycl-fallback-imf-fp64-9b8514.o /tmp/icpx-1bd1ca/libsycl-itt-user-wrappers-33cb85.o /tmp/icpx-1bd1ca/libsycl-itt-compiler-wrappers-04ffb0.o /tmp/icpx-1bd1ca/libsycl-itt-stubs-978093.o -o /tmp/icpx-1bd1ca/test-fbf499.bc --suppress-warnings "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin/sycl-post-link" -emit-only-kernels-as-entry-points -emit-param-info -symbols -emit-exported-symbols -split-esimd -lower-esimd -O2 -spec-const=default -device-globals -o /tmp/icpx-1bd1ca/test-524d75.table /tmp/icpx-1bd1ca/test-fbf499.bc "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/file-table-tform" -extract=Code -drop_titles -o /tmp/icpx-1bd1ca/test-2a8e51.txt /tmp/icpx-1bd1ca/test-524d75.table "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/llvm-foreach" --in-file-list=/tmp/icpx-1bd1ca/test-2a8e51.txt --in-replace=/tmp/icpx-1bd1ca/test-2a8e51.txt --out-ext=spv --out-file-list=/tmp/icpx-1bd1ca/test-365350.txt --out-replace=/tmp/icpx-1bd1ca/test-365350.txt --out-dir=/tmp/icpx-1bd1ca -- /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/llvm-spirv -o /tmp/icpx-1bd1ca/test-365350.txt -spirv-max-version=1.3 -spirv-debug-info-version=ocl-100 -spirv-allow-extra-diexpressions -spirv-allow-unknown-intrinsics=llvm.genx. -spirv-ext=-all,+SPV_EXT_shader_atomic_float_add,+SPV_EXT_shader_atomic_float_min_max,+SPV_KHR_no_integer_wrap_decoration,+SPV_KHR_float_controls,+SPV_KHR_expect_assume,+SPV_KHR_linkonce_odr,+SPV_INTEL_subgroups,+SPV_INTEL_media_block_io,+SPV_INTEL_device_side_avc_motion_estimation,+SPV_INTEL_fpga_loop_controls,+SPV_INTEL_unstructured_loop_controls,+SPV_INTEL_fpga_reg,+SPV_INTEL_blocking_pipes,+SPV_INTEL_function_pointers,+SPV_INTEL_kernel_attributes,+SPV_INTEL_io_pipes,+SPV_INTEL_inline_assembly,+SPV_INTEL_arbitrary_precision_integers,+SPV_INTEL_float_controls2,+SPV_INTEL_vector_compute,+SPV_INTEL_fast_composite,+SPV_INTEL_joint_matrix,+SPV_INTEL_arbitrary_precision_fixed_point,+SPV_INTEL_arbitrary_precision_floating_point,+SPV_INTEL_variable_length_array,+SPV_INTEL_fp_fast_math_mode,+SPV_INTEL_long_constant_composite,+SPV_INTEL_arithmetic_fence,+SPV_INTEL_global_variable_decorations,+SPV_INTEL_task_sequence,+SPV_INTEL_optnone,+SPV_INTEL_usm_storage_classes,+SPV_INTEL_runtime_aligned,+SPV_INTEL_fpga_cluster_attributes,+SPV_INTEL_loop_fuse,+SPV_INTEL_fpga_buffer_location,+SPV_INTEL_fpga_invocation_pipelining_attributes,+SPV_INTEL_fpga_dsp_control,+SPV_INTEL_fpga_memory_accesses,+SPV_INTEL_fpga_memory_attributes,-SPV_INTEL_optnone /tmp/icpx-1bd1ca/test-2a8e51.txt "/glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin-llvm/llvm-foreach" --out-ext=aocx --in-file-list=/tmp/icpx-1bd1ca/test-365350.txt --in-replace=/tmp/icpx-1bd1ca/test-365350.txt --out-file-list=/tmp/icpx-1bd1ca/test-3f7bf0.aocx --out-replace=/tmp/icpx-1bd1ca/test-3f7bf0.aocx --out-increment=test.prj -- /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/lib/oclfpga/bin/aoc -o /tmp/icpx-1bd1ca/test-3f7bf0.aocx /tmp/icpx-1bd1ca/test-365350.txt -sycl -dep-files=/tmp/icpx-1bd1ca/test-efa644.d -output-report-folder=test.prj -g -hardware -target=/opt/intel/oneapi/intel_s10sx_pac:pac_s10_usm aoc: Compiling for FPGA. This process may take several hours to complete. Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets. If the reports indicate performance targets are not being met, code edits may be required. Please refer to the oneAPI FPGA Optimization Guide for information on performance tuning applications for FPGAs. Error (23035): Tcl error: Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings For more details, full Quartus compile output can be found in files quartuserr.tmp and quartus_sh_compile.log. Error: Compiler Error, not able to generate hardware llvm-foreach: icpx: error: fpga compiler command failed with exit code 1 (use -v to see invocation)u180336@s001-n061:~/test2/test.prj/build$ cat compile_script.tcl # (c) 1992-2020 Intel Corporation. # Intel, the Intel logo, Intel, MegaCore, NIOS II, Quartus and TalkBack words # and logos are trademarks of Intel Corporation or its subsidiaries in the U.S. # and/or other countries. Other marks and brands may be claimed as the property # of others. See Trademarks on intel.com for full list of Intel trademarks or # the Trademarks & Brands Names Database (if Intel) or See www.Intel.com/legal (if Altera) # Your use of Intel Corporation's design tools, logic functions and other # software and tools, and its AMPP partner logic functions, and any output # files any of the foregoing (including device programming or simulation # files), and any associated documentation or information are expressly subject # to the terms and conditions of the Altera Program License Subscription # Agreement, Intel MegaCore Function License Agreement, or other applicable # license agreement, including, without limitation, that your use is for the # sole purpose of programming logic devices manufactured by Intel and sold by # Intel or its authorized distributors. Please refer to the applicable # agreement for further details. post_message "Running compile_script.tcl script" # get flow type (from quartus(args) variable) set flow [lindex $quartus(args) 0] # simplified PR Quartus flow qexec "quartus_syn --read_settings_files=on --write_settings_files=off dcp -c afu_$flow" qexec "quartus_fit --read_settings_files=on --write_settings_files=off dcp -c afu_$flow" qexec "quartus_asm --read_settings_files=on --write_settings_files=off dcp -c afu_$flow" post_message "Removing the relaxed freeze-wrapper region kernel clock constraints that were used during Fitter with the base-flow." exec sed -i {s/set_max_delay/#set_max_delay/g} user_clock.sdc post_message "Removing the added clock-uncertainty that was put in place during the Fitter to help reduce cross-talk." exec sed -i {s/set_clock_uncertainty/#set_clock_uncertainty/g} opencl_bsp.sdc qexec "quartus_sta dcp -c afu_$flow --force_dat" if {$flow eq "base"} { post_message "OpenCL BSP base revision compile..." # export green region partition qexec "quartus_cdb dcp -c afu_base --export_partition green_region --snapshot final --file green_region.qdb --exclude_pr_subblocks" # Get the kernel FMAX in the static region (by false-pathing all kernel clock paths in the PR region so they will be ignored) and dump it to a file. This is to facilitate selecting the seed with the fastest static region. post_message "Checking Kernel FMAX in static/BSP region." qexec "quartus_sta -t scripts/get_static_region_kernel_fmax.tcl" }u180336@login-2:~/test2/test.prj$ cat quartus_sh_compile.log This is the PAC OpenCL BSP run.sh script. Compiling import revision flow... ERROR: packager check failed with output '' Info: ******************************************************************* Info: Running Quartus Prime Shell Info: Version 19.2.0 Build 57 06/24/2019 Patches 0.05dcp SJ Pro Edition Info: Copyright (C) 2019 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and any partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details, at Info: https://fpgasoftware.intel.com/eula. Info: Processing started: Thu Mar 30 19:12:03 2023 Info: Command: quartus_sh -t build/entry.tcl import Info: Quartus(args): import Info: Using INI file /tmp/test-3f7bf0-fb5456/quartus.ini Info: Compiling revision import Error (23035): Tcl error: while executing "qexec "bash build/run.sh $revision_name"" ("default" arm line 9) invoked from within "switch $tcl_platform(platform) { windows { post_message -type error "Full compiles to generate hardware for the FPGA are available on supported ..." (file "build/entry.tcl" line 19) Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings Error: Peak virtual memory: 982 megabytes Error: Processing ended: Thu Mar 30 19:12:04 2023 Error: Elapsed time: 00:00:01 u180336@login-2:~/test2/test.prj$u180336@login-2:~/test2/test.prj$ cat build/entry.tcl # (c) 1992-2020 Intel Corporation. # Intel, the Intel logo, Intel, MegaCore, NIOS II, Quartus and TalkBack words # and logos are trademarks of Intel Corporation or its subsidiaries in the U.S. # and/or other countries. Other marks and brands may be claimed as the property # of others. See Trademarks on intel.com for full list of Intel trademarks or # the Trademarks & Brands Names Database (if Intel) or See www.Intel.com/legal (if Altera) # Your use of Intel Corporation's design tools, logic functions and other # software and tools, and its AMPP partner logic functions, and any output # files any of the foregoing (including device programming or simulation # files), and any associated documentation or information are expressly subject # to the terms and conditions of the Altera Program License Subscription # Agreement, Intel MegaCore Function License Agreement, or other applicable # license agreement, including, without limitation, that your use is for the # sole purpose of programming logic devices manufactured by Intel and sold by # Intel or its authorized distributors. Please refer to the applicable # agreement for further details. #Full compiles are not supported on Windows switch $tcl_platform(platform) { windows { post_message -type error "Full compiles to generate hardware for the FPGA are available on supported Linux platforms only. Please add -rtl to your invocation of aoc to compile without building hardware. Otherwise please run your compile on a supported Linux distribution." exit 2 } default { #Get revision name from quartus args if { [llength $quartus(args)] > 0 } { set revision_name [lindex $quartus(args) 0] } else { set revision_name import } post_message "Compiling revision $revision_name" qexec "bash build/run.sh $revision_name" } }u180336@login-2:~/test2/test.prj$ cat build/run.sh #!/bin/bash # (C) 2017 Intel Corporation. All rights reserved. # Your use of Intel Corporation's design tools, logic functions and other # software and tools, and its AMPP partner logic functions, and any output # files any of the foregoing (including device programming or simulation # files), and any associated documentation or information are expressly subject # to the terms and conditions of the Intel Program License Subscription # Agreement, Intel MegaCore Function License Agreement, or other applicable # license agreement, including, without limitation, that your use is for the # sole purpose of programming logic devices manufactured by Intel and sold by # Intel or its authorized distributors. Please refer to the applicable # agreement for further details. echo "This is the PAC OpenCL BSP run.sh script." # set BSP flow if [ $# -eq 0 ] then BSP_FLOW="flat" else BSP_FLOW="$1" fi echo "Compiling $BSP_FLOW revision flow..." #get exact script path SCRIPT_PATH=$(readlink -f "${BASH_SOURCE[0]}") #get director of script path SCRIPT_DIR_PATH="$(dirname "$SCRIPT_PATH")" cd "$SCRIPT_DIR_PATH" #test packager bin first to make sure it is available and working and fail #early if it can't run. #it would be frustrating to find out at the end of the compilation ADAPT_PACKAGER_BIN="python2.7 ./tools/packager.pyz" FLOW_SUCCESS=1 PACKAGER_OUTPUT=$($ADAPT_PACKAGER_BIN) FLOW_SUCCESS=$? if [ $FLOW_SUCCESS != 0 ]; then echo "ERROR: packager check failed with output '$PACKAGER_OUTPUT'" exit 1 fi #make sure bbs files exist if [ ! -f "dcp.qdb" ]; then echo "ERROR: BSP is not setup" fi #copy quartus.ini cp ../quartus.ini . #import opencl kernel files quartus_sh -t scripts/import_opencl_kernel.tcl #check for bypass/alternative flows if [ "$DCP_BYPASS_OPENCL_RUN_SCRIPT" != "" ]; then sh $DCP_BYPASS_OPENCL_RUN_SCRIPT exit $? fi #add BBBs to quartus pr project quartus_sh -t add_bbb_to_pr_project.tcl $BSP_FLOW cp ../afu_opencl_kernel.qsf . echo "qsys-generate board.qsys" qsys-generate -syn --quartus-project=dcp --rev=afu_opencl_kernel --parallel=off board.qsys # adding board.qsys and corresponding .ip parameterization files to opencl_bsp_ip.qsf qsys-archive --quartus-project=dcp --rev=afu_opencl_kernel --add-to-project board.qsys #append kernel_system qsys/ip assignments to all revisions rm -f kernel_system_qsf_append.txt echo >> kernel_system_qsf_append.txt grep -A10000 OPENCL_KERNEL_ASSIGNMENTS_START_HERE afu_opencl_kernel.qsf >> kernel_system_qsf_append.txt echo >> kernel_system_qsf_append.txt cat kernel_system_qsf_append.txt >> afu_flat.qsf cat kernel_system_qsf_append.txt >> afu_base.qsf cat kernel_system_qsf_append.txt >> afu_import.qsf # compile project # ===================== quartus_sh -t compile_script.tcl $BSP_FLOW FLOW_SUCCESS=$? # Report Timing # ============= if [ $FLOW_SUCCESS -eq 0 ] then quartus_sh -t scripts/adjust_plls_mcp.tcl dcp afu_$BSP_FLOW else echo "ERROR: kernel compilation failed. Please see quartus_sh_compile.log for more information." exit 1 fi #run packager tool to create GBS BBS_ID_FILE="fme-ifc-id.txt" if [ -f "$BBS_ID_FILE" ]; then FME_IFC_ID=`cat $BBS_ID_FILE` else echo "ERROR: fme id not found." exit 1 fi PLL_METADATA="" PLL_METADATA_FILE="pll_metadata.txt" if [ -f "$PLL_METADATA_FILE" ]; then PLL_METADATA=`cat $PLL_METADATA_FILE` echo "run.sh: PLL_METADATA/PLL_METADATA_FILE is: " cat $PLL_METADATA_FILE fi #check for generated rbf and gbs files if [ ! -f ./output_files/afu_$BSP_FLOW.green_region.rbf ]; then echo "ERROR: ./output_files/afu_$FLOW.green_region.rbf is missing!" exit 1 fi rm -f afu.gbs $ADAPT_PACKAGER_BIN create-gbs \ --rbf ./output_files/afu_$BSP_FLOW.green_region.rbf \ --gbs ./output_files/afu_$BSP_FLOW.gbs \ --afu-json opencl_afu.json \ --set-value \ interface-uuid:$FME_IFC_ID \ $PLL_METADATA FLOW_SUCCESS=$? if [ $FLOW_SUCCESS != 0 ]; then echo "ERROR: packager tool failed to create .gbs file." exit 1 fi rm -rf fpga.bin gzip -9c ./output_files/afu_$BSP_FLOW.gbs > afu_$BSP_FLOW.gbs.gz aocl binedit fpga.bin create aocl binedit fpga.bin add .acl.gbs.gz ./afu_$BSP_FLOW.gbs.gz echo "run.sh: done zipping up the gbs into gbs.gz, and creating fpga.bin" if [ -f afu_$BSP_FLOW.failing_clocks.rpt ]; then aocl binedit fpga.bin add .failing_clocks.rpt ./afu_$BSP_FLOW.failing_clocks.rpt cp ./afu_$BSP_FLOW.failing_clocks.rpt ../ echo "run.sh: done appending failing clocks report to fpga.bin" fi if [ -f afu_$BSP_FLOW.failing_paths.rpt ]; then aocl binedit fpga.bin add .failing_paths.rpt ./afu_$BSP_FLOW.failing_paths.rpt cp ./afu_$BSP_FLOW.failing_paths.rpt ../ echo "run.sh: done appending failing paths report to fpga.bin" fi if [ ! -f fpga.bin ]; then echo "ERROR: no fpga.bin found. FPGA compilation failed!" exit 1 fi #copy fpga.bin to parent directory so aoc flow can find it cp fpga.bin ../ cp acl_quartus_report.txt ../ echo "" echo "===========================================================================" echo "OpenCL AFU compilation complete" echo "===========================================================================" echo "" u180336@login-2:~/test2/test.prj$ u180336@login-2:~/test2/test.prj$ cat build/run.sh #!/bin/bash # (C) 2017 Intel Corporation. All rights reserved. # Your use of Intel Corporation's design tools, logic functions and other # software and tools, and its AMPP partner logic functions, and any output # files any of the foregoing (including device programming or simulation # files), and any associated documentation or information are expressly subject # to the terms and conditions of the Intel Program License Subscription # Agreement, Intel MegaCore Function License Agreement, or other applicable # license agreement, including, without limitation, that your use is for the # sole purpose of programming logic devices manufactured by Intel and sold by # Intel or its authorized distributors. Please refer to the applicable # agreement for further details. echo "This is the PAC OpenCL BSP run.sh script." # set BSP flow if [ $# -eq 0 ] then BSP_FLOW="flat" else BSP_FLOW="$1" fi echo "Compiling $BSP_FLOW revision flow..." #get exact script path SCRIPT_PATH=$(readlink -f "${BASH_SOURCE[0]}") #get director of script path SCRIPT_DIR_PATH="$(dirname "$SCRIPT_PATH")" cd "$SCRIPT_DIR_PATH" #test packager bin first to make sure it is available and working and fail #early if it can't run. #it would be frustrating to find out at the end of the compilation ADAPT_PACKAGER_BIN="python2.7 ./tools/packager.pyz" FLOW_SUCCESS=1 PACKAGER_OUTPUT=$($ADAPT_PACKAGER_BIN) FLOW_SUCCESS=$? if [ $FLOW_SUCCESS != 0 ]; then echo "ERROR: packager check failed with output '$PACKAGER_OUTPUT'" exit 1 fi #make sure bbs files exist if [ ! -f "dcp.qdb" ]; then echo "ERROR: BSP is not setup" fi #copy quartus.ini cp ../quartus.ini . #import opencl kernel files quartus_sh -t scripts/import_opencl_kernel.tcl #check for bypass/alternative flows if [ "$DCP_BYPASS_OPENCL_RUN_SCRIPT" != "" ]; then sh $DCP_BYPASS_OPENCL_RUN_SCRIPT exit $? fi #add BBBs to quartus pr project quartus_sh -t add_bbb_to_pr_project.tcl $BSP_FLOW cp ../afu_opencl_kernel.qsf . echo "qsys-generate board.qsys" qsys-generate -syn --quartus-project=dcp --rev=afu_opencl_kernel --parallel=off board.qsys # adding board.qsys and corresponding .ip parameterization files to opencl_bsp_ip.qsf qsys-archive --quartus-project=dcp --rev=afu_opencl_kernel --add-to-project board.qsys #append kernel_system qsys/ip assignments to all revisions rm -f kernel_system_qsf_append.txt echo >> kernel_system_qsf_append.txt grep -A10000 OPENCL_KERNEL_ASSIGNMENTS_START_HERE afu_opencl_kernel.qsf >> kernel_system_qsf_append.txt echo >> kernel_system_qsf_append.txt cat kernel_system_qsf_append.txt >> afu_flat.qsf cat kernel_system_qsf_append.txt >> afu_base.qsf cat kernel_system_qsf_append.txt >> afu_import.qsf # compile project # ===================== quartus_sh -t compile_script.tcl $BSP_FLOW FLOW_SUCCESS=$? # Report Timing # ============= if [ $FLOW_SUCCESS -eq 0 ] then quartus_sh -t scripts/adjust_plls_mcp.tcl dcp afu_$BSP_FLOW else echo "ERROR: kernel compilation failed. Please see quartus_sh_compile.log for more information." exit 1 fi #run packager tool to create GBS BBS_ID_FILE="fme-ifc-id.txt" if [ -f "$BBS_ID_FILE" ]; then FME_IFC_ID=`cat $BBS_ID_FILE` else echo "ERROR: fme id not found." exit 1 fi PLL_METADATA="" PLL_METADATA_FILE="pll_metadata.txt" if [ -f "$PLL_METADATA_FILE" ]; then PLL_METADATA=`cat $PLL_METADATA_FILE` echo "run.sh: PLL_METADATA/PLL_METADATA_FILE is: " cat $PLL_METADATA_FILE fi #check for generated rbf and gbs files if [ ! -f ./output_files/afu_$BSP_FLOW.green_region.rbf ]; then echo "ERROR: ./output_files/afu_$FLOW.green_region.rbf is missing!" exit 1 fi rm -f afu.gbs $ADAPT_PACKAGER_BIN create-gbs \ --rbf ./output_files/afu_$BSP_FLOW.green_region.rbf \ --gbs ./output_files/afu_$BSP_FLOW.gbs \ --afu-json opencl_afu.json \ --set-value \ interface-uuid:$FME_IFC_ID \ $PLL_METADATA FLOW_SUCCESS=$? if [ $FLOW_SUCCESS != 0 ]; then echo "ERROR: packager tool failed to create .gbs file." exit 1 fi rm -rf fpga.bin gzip -9c ./output_files/afu_$BSP_FLOW.gbs > afu_$BSP_FLOW.gbs.gz aocl binedit fpga.bin create aocl binedit fpga.bin add .acl.gbs.gz ./afu_$BSP_FLOW.gbs.gz echo "run.sh: done zipping up the gbs into gbs.gz, and creating fpga.bin" if [ -f afu_$BSP_FLOW.failing_clocks.rpt ]; then aocl binedit fpga.bin add .failing_clocks.rpt ./afu_$BSP_FLOW.failing_clocks.rpt cp ./afu_$BSP_FLOW.failing_clocks.rpt ../ echo "run.sh: done appending failing clocks report to fpga.bin" fi if [ -f afu_$BSP_FLOW.failing_paths.rpt ]; then aocl binedit fpga.bin add .failing_paths.rpt ./afu_$BSP_FLOW.failing_paths.rpt cp ./afu_$BSP_FLOW.failing_paths.rpt ../ echo "run.sh: done appending failing paths report to fpga.bin" fi if [ ! -f fpga.bin ]; then echo "ERROR: no fpga.bin found. FPGA compilation failed!" exit 1 fi #copy fpga.bin to parent directory so aoc flow can find it cp fpga.bin ../ cp acl_quartus_report.txt ../ echo "" echo "===========================================================================" echo "OpenCL AFU compilation complete" echo "===========================================================================" echo "" - hareesh
sorry for the late response. I did not face any issues at execution time on s10.
please follow bellow article and once again try to execute the same code.
https://devcloud.intel.com/oneapi/get_started/baseToolkitSamples/#toolkitExample
- hareesh
can you please update status of your issue?
- hareesh
