ThanhN
1 year agoEltwise_mult with broadcasting on FPGA
Hi, I am using FPGA AI suite 2025.1 & OpenVINO 2024.6.0 with DE10-Agilex dev kit. In ".arch" files provided , such as AGX7_Performance.arch, I see "enable_eltwise_mult : true". But it seems not sup...
- 1 year ago
May I know if you have any other queries?
JohnT_Altera
1 year agoHi,
The enable_eltwise_mult is used for MobilenetV3 network architecture. May I know what type of the Broadcast network architecture are you using? If there is a different on the implementation then it will not support broadcasting.
- ThanhN1 year ago
I’m working with a customized model, and one of the steps involves applying a mask with shape [1, 1, H, W] to crossing 96 channels of a feature-level tensor of shape [1, 96, H, W], which is the output of a convolution layer. In PyTorch, this can be done using torch.mul(tensor1, tensor2) where broadcasting handles the channel mismatch and performs element-wise multiplication.
Is there a way to make this operation work directly on an FPGA? I want the entire model computation to be executed on the FPGA without involving the CPU. It seems to me that the "enable_eltwise_mult: true" not perform broadcasting that handles the channel mismatch. I may be wrong.
Thanks!
