Hi @student4,
Thank you for posting in Intel community forum on your interest in oneAPI and hope all is well.
Mind if I asked what libraries is used in the DPC++ code? Would it be convenient for you to share the mention test project which contain both C++ and DPC++ code?
And are you using the Intel Devcloud to run the emulation?
Hope to hear from you soon.
Best Wishes
BB
Hi BB,
Thank you for your reply.
I am using Microsoft Visual Studio 2019 to run the emulation.
I am not able to attach the file. Please refer to the test project implementation below
#include <iostream>
#include <numeric>
#include <chrono>
#include <iomanip>
#include <complex>
#include <array>
#include <vector>
#include<fstream>
//#define standard_cpp
#define oneApi_FPGA
#ifdef standard_cpp
#include "../Standard_CPP/standardCPPFile.h"
#endif
#ifdef oneApi_FPGA
#include "../Oneapi_FPGA/DPCPPFile.h"
#endif
using namespace std;
void Test()
#ifdef standard_cpp
DPCPPFile obj;
#endif
#ifdef oneApi_FPGA
standardCPPFile obj;
#endif
for (int i = 0; i < 999000; i++)
obj.func();
int main()
Test();
cout << "success" << endl;
return 0;
The test project calls both standard C++ and DPC++ versions of the function->func
This is a sample implementation of func in DPC++.
void DPCPPFile::func(int v)
std::vector<std::complex<float>>Atemp(7);
std::vector<std::complex<float>>Btemp(7);
std::vector<std::vector<std::complex<float>>>Ztemp(7);
// std::cout << "find best symbol index is" << v << std::endl;
cl::sycl::ext::intel::fpga_emulator_selector d_selector;
// queue declaration
cl::sycl::queue Q(d_selector);
sycl::buffer AtempBuff(Atemp);
sycl::buffer BtempBuff(Btemp);
sycl::buffer ZtempBuff(Ztemp);
Q.submit([&](sycl::handler& h)
sycl::accessor AtempAccess(AtempBuff, h, sycl::write_only);
sycl::accessor BtempAccess(BtempBuff, h, sycl::read_only);
sycl::accessor ZtempAccess(ZtempBuff, h, sycl::read_only);
h.parallel_for(sycl::range<1>(Nr), [=](auto idx)
AtempAccess[idx] = std::conj(BtempAccess[v - 1]) * ZtempAccess[v][idx];
sycl::host_accessor AtempHost(AtempBuff);
Below is the same implementation in standard CPP
void standardCPPFile::func(int v,int Nr)
std::vector<std::complex<float>>Ztemp(7);
// std::cout << "find best symbol index is" << v << std::endl;.
for (int i = 0; i < Nr; i++)
Atemp[Nr] += std::conj(Btemp[v - 1]) * Ztemp[v][Nr];
Thank you.
