Downsample block and TDM/TDD blocks in DSPBuilder Advanced Blockset
- 5 years ago
You may need a dual clock FIFO to transfer data between two different clock domains.
Regards -SK
I'm not familiar with third party tool, however, It looks similar to the DEMUX and MUX block in the primitive library, But please remind that the DSP Builder Advance block set uses only a single clock domain.
For example:
MUX: If the input sample rate is 1/3 of the system clock rate, and there are three input ports. On every clock cycle, you can use the "S" signal to select which input data to go out first and then followed by second and third. This means the input data is without TDM, but the output data can with TDM.
DEMUX: Reverse of MUX. The input data is with TDM, however, the output sample is without TDM.
Regards -SK
Dear SengKok,
Thank you for the clarification.
In attempting to use DSP Builder to build a multirate system, I attempted to generate two DSP Builder custom components, each operating on a different clock domain, and connect data signals between the two custom components in platform designer.
Unfortunately it seems like it is not possible to connect conduit interfaces which are on different clock domains? Please see the attached screenshot below, which contains an error message highlighted.
Is there a workaround for this? Maybe create another clock port on my "NCO..." custom component, and associate this slower clock with the output signals I intend to send to the slower clock "mixer_128..." custom component?
