Component Done signal remains asserted in FPGA, not in Simulation
I have created a component in HLS which should take a 1280 bit signal (passed by value), and should stream it out in 20 packets of 64-bit each.
The task is simple, and both the simulation and co-simulation in Modelsim work fine.
However, when I integrate this component in my design, I have observed with signalTap that the done signal once asserted for the first time it remains high, it does not go back to 0 after one clock cycle and the component hangs, being impossible to start it again as soon as new input data becomes available.
I have also realized, that if I stream out 3 packets or less, the signal gets properly de-asserted after one clock cycle as I would expect, and the component does not hang.
This is the code I have used:
void component algorithm_1((ac_int<1280> in, ihc::stream_out<ac_int<64,false>, ihc::firstSymbolInHighOrderBits<false>> &out_stream)) { ac_int<64> result = 0; for (char i = 0; i<20; i++) { result = (in >> 64*i) & 0xFFFFFFFFFFFFFFFF ; out_stream.write(result); } }
What could be the reason why the Done signal remains asserted? I have checked the internals of the component, but I have not found any FIFO overflow on the IOWR
Thanks for your help
1 Reply
- AnilErinch_A_Intel
Hi ,
Can you share the signal tap waveforms for the 3 packets scenario and hanging scenario.
Also can you please let us know the status of the stall signal when the component hangs.
Thanks and Regards
Anil
