Hi @Kevin_Xu_Intel ,
Thank you for your answer :
1. My OS is Ubuntu 20.04
2. Here is the output of the "printenv" command
SHELL=/bin/bash
TBBROOT=/opt/intel/oneapi/tbb/2021.13/env/..
SESSION_MANAGER=local/user:@/tmp/.ICE-unix/1639,unix/user:/tmp/.ICE-unix/1639
QT_ACCESSIBILITY=1
COLORTERM=truecolor
XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg
XDG_MENU_PREFIX=gnome-
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
ONEAPI_ROOT=/opt/intel/oneapi
PKG_CONFIG_PATH=/opt/intel/oneapi/vtune/2024.2/include/pkgconfig/lib64:/opt/intel/oneapi/tbb/2021.13/env/../lib/pkgconfig:/opt/intel/oneapi/mpi/2021.13/lib/pkgconfig:/opt/intel/oneapi/mkl/2024.2/lib/pkgconfig:/opt/intel/oneapi/ippcp/2021.12/lib/pkgconfig:/opt/intel/oneapi/dpl/2022.6/lib/pkgconfig:/opt/intel/oneapi/dnnl/2024.2/lib/pkgconfig:/opt/intel/oneapi/dal/2024.5/lib/pkgconfig:/opt/intel/oneapi/compiler/2024.2/lib/pkgconfig:/opt/intel/oneapi/ccl/2021.13/lib/pkgconfig/:/opt/intel/oneapi/advisor/2024.2/include/pkgconfig/lib64:
GNOME_SHELL_SESSION_MODE=ubuntu
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
CCL_ROOT=/opt/intel/oneapi/ccl/2021.13
I_MPI_ROOT=/opt/intel/oneapi/mpi/2021.13
XMODIFIERS=@im=ibus
DESKTOP_SESSION=ubuntu
FI_PROVIDER_PATH=/opt/intel/oneapi/mpi/2021.13/opt/mpi/libfabric/lib/prov:/usr/lib/x86_64-linux-gnu/libfabric
SSH_AGENT_PID=1601
DNNLROOT=/opt/intel/oneapi/dnnl/2024.2
DIAGUTIL_PATH=/opt/intel/oneapi/dpcpp-ct/2024.2/etc/dpct/sys_check/sys_check.sh:/opt/intel/oneapi/debugger/2024.2/etc/debugger/sys_check/sys_check.py:/opt/intel/oneapi/compiler/2024.2/etc/compiler/sys_check/sys_check.sh
ADVISOR_2024_DIR=/opt/intel/oneapi/advisor/2024.2
GTK_MODULES=gail:atk-bridge
PWD=/home/user
CCL_CONFIGURATION=cpu_gpu_dpcpp
LOGNAME=user
XDG_SESSION_DESKTOP=ubuntu
QSYS_ROOTDIR=/opt/intelFPGA_pro/23.1/qsys/bin
DPL_ROOT=/opt/intel/oneapi/dpl/2022.6
XDG_SESSION_TYPE=x11
MANPATH=/opt/intel/oneapi/mpi/2021.13/share/man:/opt/intel/oneapi/debugger/2024.2/share/man:/opt/intel/oneapi/compiler/2024.2/share/man:
GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
QUARTUS_ROOTDIR_OVERRIDE=/opt/intelFPGA_pro/23.1/quartus
XAUTHORITY=/run/user/1000/gdm/Xauthority
GJS_DEBUG_TOPICS=JS ERROR;JS LOG
WINDOWPATH=2
HOME=/home/user
USERNAME=user
IM_CONFIG_PHASE=1
GDB_INFO=/opt/intel/oneapi/debugger/2024.2/share/info/
CCL_CONFIGURATION_PATH=
LANG=fr_FR.UTF-8
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
XDG_CURRENT_DESKTOP=ubuntu:GNOME
VTE_VERSION=6003
SETVARS_COMPLETED=1
APM=/opt/intel/oneapi/advisor/2024.2/perfmodels
CMAKE_PREFIX_PATH=/opt/intel/oneapi/tbb/2021.13/env/..:/opt/intel/oneapi/mkl/2024.2/lib/cmake:/opt/intel/oneapi/ipp/2021.12/lib/cmake/ipp:/opt/intel/oneapi/dpl/2022.6/lib/cmake/oneDPL:/opt/intel/oneapi/dnnl/2024.2/lib/cmake:/opt/intel/oneapi/dal/2024.5:/opt/intel/oneapi/compiler/2024.2
GNOME_TERMINAL_SCREEN=/org/gnome/Terminal/screen/73641c1f_3637_4d02_b1b6_e43e9ee4808b
INVOCATION_ID=4dfc70fc819a4c6b8199de4aad6eb293
MANAGERPID=1241
CMPLR_ROOT=/opt/intel/oneapi/compiler/2024.2
INFOPATH=/opt/intel/oneapi/debugger/2024.2/share/info
GJS_DEBUG_OUTPUT=stderr
IPPROOT=/opt/intel/oneapi/ipp/2021.12
IPP_TARGET_ARCH=intel64
LESSCLOSE=/usr/bin/lesspipe %s %s
XDG_SESSION_CLASS=user
PYTHONPATH=/opt/intel/oneapi/advisor/2024.2/pythonapi
TERM=xterm-256color
DALROOT=/opt/intel/oneapi/dal/2024.5
LESSOPEN=| /usr/bin/lesspipe %s
USER=user
LIBRARY_PATH=/opt/intel/oneapi/tbb/2021.13/env/../lib/intel64/gcc4.8:/opt/intel/oneapi/mpi/2021.13/lib:/opt/intel/oneapi/mkl/2024.2/lib/:/opt/intel/oneapi/ippcp/2021.12/lib/:/opt/intel/oneapi/ipp/2021.12/lib:/opt/intel/oneapi/dpl/2022.6/lib:/opt/intel/oneapi/dnnl/2024.2/lib:/opt/intel/oneapi/dal/2024.5/lib:/opt/intel/oneapi/compiler/2024.2/lib:/opt/intel/oneapi/ccl/2021.13/lib/
DAL_MAJOR_BINARY=2
GNOME_TERMINAL_SERVICE=:1.82
IPPCRYPTOROOT=/opt/intel/oneapi/ippcp/2021.12
DISPLAY=:0
QUARTUS_ROOTDIR=/opt/intelFPGA_pro/23.1/quartus
IPPCP_TARGET_ARCH=intel64
SHLVL=1
VTUNE_PROFILER_2024_DIR=/opt/intel/oneapi/vtune/2024.2
QT_IM_MODULE=ibus
OCL_ICD_FILENAMES=/opt/intel/oneapi/compiler/2024.2/lib/libintelocl.so
LM_LICENSE_FILE=/opt/intelFPGA_pro/LR-177233_License.dat
CLASSPATH=/opt/intel/oneapi/mpi/2021.13/share/java/mpi.jar
INTELFPGAOCLSDKROOT=/opt/intelFPGA_pro/23.1/hld
LD_LIBRARY_PATH=/opt/intel/oneapi/tbb/2021.13/env/../lib/intel64/gcc4.8:/opt/intel/oneapi/mpi/2021.13/opt/mpi/libfabric/lib:/opt/intel/oneapi/mpi/2021.13/lib:/opt/intel/oneapi/mkl/2024.2/lib:/opt/intel/oneapi/ippcp/2021.12/lib/:/opt/intel/oneapi/ipp/2021.12/lib:/opt/intel/oneapi/dpl/2022.6/lib:/opt/intel/oneapi/dnnl/2024.2/lib:/opt/intel/oneapi/debugger/2024.2/opt/debugger/lib:/opt/intel/oneapi/dal/2024.5/lib:/opt/intel/oneapi/compiler/2024.2/opt/compiler/lib:/opt/intel/oneapi/compiler/2024.2/lib:/opt/intel/oneapi/ccl/2021.13/lib/
VTUNE_PROFILER_DIR=/opt/intel/oneapi/vtune/2024.2
QROOT=/opt/intelFPGA_pro/23.1
XDG_RUNTIME_DIR=/run/user/1000
MKLROOT=/opt/intel/oneapi/mkl/2024.2
DAL_MINOR_BINARY=0
JOURNAL_STREAM=8:47110
XDG_DATA_DIRS=/usr/share/ubuntu:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop
NLSPATH=/opt/intel/oneapi/mkl/2024.2/share/locale/%l_%t/%N:/opt/intel/oneapi/compiler/2024.2/lib/compiler/locale/%l_%t/%N
PATH=/opt/intel/oneapi/vtune/2024.2/bin64:/opt/intel/oneapi/mpi/2021.13/bin:/opt/intel/oneapi/mkl/2024.2/bin/:/opt/intel/oneapi/dpcpp-ct/2024.2/bin:/opt/intel/oneapi/dev-utilities/2024.2/bin:/opt/intel/oneapi/debugger/2024.2/opt/debugger/bin:/opt/intel/oneapi/compiler/2024.2/bin:/opt/intel/oneapi/advisor/2024.2/bin64:/opt/intelFPGA_pro/23.1/questa_fe/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/opt/intelFPGA_pro/23.1/quartus/bin:/opt/intelFPGA_pro/23.1/quartus/linux64:/opt/intelFPGA_pro/23.1/quartus/qsys/bin:/opt/intelFPGA_pro/23.1/quartus/sopc_builder/bin:/opt/intelFPGA_pro/23.1/questa_fse/bin:/opt/intelFPGA_pro/23.1/quartus/bin
GDMSESSION=ubuntu
INTEL_PYTHONHOME=/opt/intel/oneapi/debugger/2024.2/opt/debugger
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
CPATH=/opt/intel/oneapi/tbb/2021.13/env/../include:/opt/intel/oneapi/mpi/2021.13/include:/opt/intel/oneapi/mkl/2024.2/include:/opt/intel/oneapi/ippcp/2021.12/include:/opt/intel/oneapi/ipp/2021.12/include:/opt/intel/oneapi/dpl/2022.6/include:/opt/intel/oneapi/dpcpp-ct/2024.2/include:/opt/intel/oneapi/dnnl/2024.2/include:/opt/intel/oneapi/dev-utilities/2024.2/include:/opt/intel/oneapi/dal/2024.5/include/dal:/opt/intel/oneapi/ccl/2021.13/include
_=/usr/bin/printenv
3. The command "aocl -diagnose" is not found on my system even after loading the oneAPI environment variables. Does it means that I don't have the FPGA compiler ?
Thank you !
DorianL
