cl::Platform::getDevice() returning error for hardware platform
My app finds the device platforms that include the a10_ref emulator and (presumably) the actual hardware. But in the host code, when the platform is queried for devices, only the emulator is returning a valid device. I get an error code returned from getDevices() using the hardware platform instance.
I also am seeing this:
$ aocl list-devices
Warning:
No devices attached for package:
/home/okramer/intelFPGA_pro/19.3/hld/board/a10_ref
--------------------------------------------------------------------Here is the output from the print_platform_info() host utility function:
Number of Platforms: 4
Platform Number: 0
Platform Name: Intel(R) FPGA Emulation Platform for OpenCL(TM)
Platform Profile: EMBEDDED_PROFILE
Platform Version: OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
Platform Vendor: Intel(R) Corporation
Platform Number: 1
Platform Name: Intel(R) FPGA SDK for OpenCL(TM)
Platform Version: OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.3
Platform Number: 2
Platform Name: Intel(R) CPU Runtime for OpenCL(TM) Applications
Platform Profile: FULL_PROFILE
Platform Version: OpenCL 2.1 LINUX
Platform Number: 3
Platform Name: NVIDIA CUDA
Platform Version: OpenCL 1.2 CUDA 10.2.95
Platform Vendor: NVIDIA CorporationWhen I select platform 0 (emulator), I can successfully call platform.getDevices(). The output of print_device_info() is:
Number of Devices in Platform: 1
Device Number: 0
Device Name: Intel(R) FPGA Emulation Device
Device Vendor: Intel(R) Corporation
Is Device Available?: 1
Is Device Little Endian?: 1
Device Max Compute Units: 20
Device Max Work Item Dimensions: 3
Device Max Work Group Size: 67108864
Device Max Frequency: 3500
Device Max Mem Alloc Size: 33715263488However, when I select platform 1, platform.getDevices() returns -1 with an empty device list. What could the problem be?
I have an Arria 10 GX dev kit plugged into the PCIe and USB of an Ubuntu 16.04 machine. Below is the host code snippet fetching platform and device:
bool getContextAndDevices(const std::string& mode,
cl::Platform& platform,
cl::Context& context,
std::vector<cl::Device>& DeviceList)
cl_int err;
// Set up map with mode-string as key and search-string as value for searching instance
// of platform in platform listing. Not sure about "sim" but not using yet:
std::map<std::string, std::string> platformNames;
platformNames.insert({"emu","Emulation"});
platformNames.insert({"sim","CPU"});
platformNames.insert({"hw","SDK"});
// Get list of available platforms:
std::vector<cl::Platform> PlatformList;
err = cl::Platform::get(&PlatformList);
checkErr(err, "Get Platform List");
checkErr(PlatformList.size()>=1 ? CL_SUCCESS : -1, "cl::Platform::get");
print_platform_info(&PlatformList);
// Look for desired platform by searching platform names using unique id string in map:
uint current_platform_id =
get_platform_id_with_string(&PlatformList, platformNames.find(mode)->second.c_str());
printf("Using Platform: %d\n\n", current_platform_id);
platform = PlatformList[current_platform_id];
// Fetch devices associated with this device. Works for "emu" but fails for "hw":
//err = platform.getDevices(CL_DEVICE_TYPE_ACCELERATOR, &DeviceList);
err = platform.getDevices(CL_DEVICE_TYPE_ALL, &DeviceList);
checkErr(err, "Get Devices");
print_device_info(&DeviceList);
//Create Context
context = cl::Context(DeviceList, NULL, NULL, NULL, &err);
checkErr(err, "Context Constructor");
return true;
}Hi okramer ,
What's the kernel version of your Ubuntu?
I've reproduce you issue, pls try my command line instruction (you have to use your Quartus version in commands):
1. Check if card connected by USB: " lsusb|grep Altera "
2. Go to .../intelFPGA_pro/18.1/quartus/bin and make "sudo killall -9 ./jtagd"
sudo ./jtagd
3 . /jtagconfig
4 ./jtagconfig --setparam 1 JtagClock 6M
5 . /jtagconfig --getparam 1 JtagClock
6. Uncompress the following file .../intelFPGA_pro/18.1/hld/board/a10_ref/bringup/a10_ref_initialization.tgz to a temporary location
7. In tmp folder: .../intelFPGA_pro/18.1/quartus/bin/quartus_pgm -l
8. .../intelFPGA_pro/18.1/quartus/bin/quartus_pgm -c 1 -m JTAG -o "p;max5_150.pof@2"
9. .../intelFPGA_pro/18.1/quartus/bin/quartus_pgm -c 1 -m JTAG -o "p;top.sof"
10. sudo reboot (It must be soft reboot!)
11. Do "lspci". Altera device should be in PCI list of devices.
12. Go to .../intelFPGA_pro/18.1/hld and do "source init_opencl.sh".
13. Go to .../intelFPGA_pro/18.1/hld/bin and do "sudo aocl install".
14. sudo reboot. (soft reboot!) After reboot do source init_opencl.sh
15. Check the card status via "aocl diagnose". Check the temperature of the card.
16. Test PCI-E speed via "aocl diagnose all".
- okramer
I found the problem was that the board installation (via "aocl install") was somehow defective. I had to uninstall and reinstall the a10_ref board and now I can see the device. Is it normal for the board installation to be corrupted somehow?
- MEIYAN_L_Intel
This error might be due to the reason as below:
- Installation not successful or
- The computer processing instruction interrupt the installation or
- The file/path to install driver is not available while install the driver.
- GRN
Hi okramer ,
sudo ./jtagd
3 . /jtagconfig
- GRN
You should do these steps after every hard reboot (dev kit card doesn't save drivers after power switch off)
- okramer
I'm running Ubuntu 16.04. It must have been a faulty or corrupted install. It works now.
