MN_
7 years agoCan I read and write buffers simultaneously with OpenCL.
Hello, I am using the FPGA board de5net from Terasic with a Stratix V FPGA. It is connected the to host via PCIe. To obtain a hight throughput I want to read an write buffers simultaneously but unf...
MN_
7 years agoHi,
thank you very much for your answer.
Unfortunately I have not found an answer for my problem. I already use two different queues and perform the read/write operations in a non-blocking fashion as HRZ recommends it. But when I analyze the execution times, I can see that all commands where executed consecutively.
I also asked the Terasic suppoort but they didn't answer yet.
So I really would appreciate it if you could help me.
MN.
Nooraini_Y_Intel
7 years agoHi MN.,
Noted. I will need time to assign/find someone to assist you. Please do expect some delay in response from the assigned agent.
Thank you.
Nooraini
