jjb169
1 year agoAgilex 7 I-Series "aocl diagnose acl0" error following OFS
Hello, I've been working through the Open FPGA Stack (OFS) guides to set up my Agilex 7 I-Series development kit for use with oneAPI. I've worked through prior SystemVerilog issues encountered by sw...
JohnT_Altera
9 months agoHi,
Can you try to implement the workaround in Why do I unexpectedly observe intermittent DDM Errors? | Altera Community - 349714?
jjb169
9 months agoHello,
I had already implemented that patch before encountering these network errors, so that fix does not seem to apply to this case, thank you for the recommendation regardless! Any other suggestions would be greatly appreciated as I look towards potentially upgrading my system's RAM.
Best,
James
