Agilex 7 I-Series "aocl diagnose acl0" error following OFS
From the design, it looks good. May I know which exact OPN of the board that you are using? Have you tested with non-oneAPI AFU design to test if your FIM and AFU is working?
Can you also provide the command and script that you use to performed the full compilation?
Thank you for checking the Quartus design! The OPN for the device on my board is AGIB027R29A1E1VB, and for reference the board was purchased at mouser with this link: https://www.mouser.com/ProductDetail/Altera/DK-DEV-AGI027-RA?qs=Znm5pLBrcAL6FowUR8Vkgw%3D%3D. I did make sure to update the part number within the configuration scripts as well, per the instructions in the guide. I did not modify any pin out information, however, as the default device also used an R29A package, so I assume that is okay.
I did not yet try testing the FIM using an AFU developed in Quartus without oneAPI, but was going to look into that and basic reference designs next to validate functionality as you suggest.
The command that I used to compile the FIM is as follows:
./ofs-common/scripts/common/syn/build_top.sh -p --ofss tools/ofss_config/pcie/pcie_host_2link_1pf_1vf.ofss iseries-dk:null_he_lb,null_he_hssi,null_he_mem,null_he_mem_tg,no_hssi work_iseries-dk_minimal_fim
I followed the steps in the minimal FIM part of the OFS guide (https://ofs.github.io/ofs-2024.2-1/hw/iseries_devkit/dev_guides/fim_dev/ug_ofs_iseries_dk_fim_dev/#45-minimal-fim) to create a PCIe 2x8 1PF/1VF Minimal FIM.
I look forward to hearing from you!
James
