Agilex 7 I-Series "aocl diagnose acl0" error following OFS
Are you using creating your own bsp or this is the BSP release from github? Can you share how you implement it?
- jjb1691 year ago
Thank you for your response! I've been keeping an eye on when the forums would come back online, but must've missed the launch day.
I have tried both my own, minimal FIM and BSP, as well as those released on the Github page.
For my own BSP, I've tried both the 1x16 1PF/1VF minimal FIM (which resulted in SystemVerilog errors previously mentioned), as well as a 2x8 1PF/1VF minimal FIM (resulting in the aocl diagnose acl0 error). The command for generating the 2x8 FIM is as follows, and is taken from the OFS guides:
./ofs-common/scripts/common/syn/build_top.sh -p --ofss tools/ofss_config/pcie/pcie_host_2link_1pf_1vf.ofss iseries-dk:null_he_lb,null_he_hssi,null_he_mem,null_he_mem_tg,no_hssi work_iseries-dk_minimal_fim
As for the pre-built FIMs I have tried wrapping into a BSP for use, I've downloaded them from the assets section of the 2024.2-1 OFS Github at the below link.
https://github.com/OFS/ofs-agx7-pcie-attach/releases/tag/ofs-2024.2-1I'll go through all of the available pre-built packages once more to ensure I did not miss anything, but none of them have worked for me yet.
I look forward to hearing from you!
James
- Anonymous1 year agoNot applicable
May I know which OS are you using? Have you try to use the pre-compile design directly?
- jjb1691 year ago
I've been using Red Hat Linux 8.10 as specified in the Github and parts of the OFS tutorial like for installing DFL and OPAE. I see that it says Red Hat 8.8 in your provided screenshot, should I change to that version instead?
When you say using the pre-compiled designs directly, do you mean the FIMs provided on the Github in packages like "iseries-dk-images_ofs-2024-2-1.tar.gz"? If so, then yes, I have tried the one I just mentioned, as well as the "iseries-dk-slimfim-images_ofs-2024-2-1.tar.gz" without any success. I am able to create the BSP successfully and generate the initialization bitstream, but run into the DMA errors previously mentioned. I will try the other 2link and 1link configurations now as well to see if those yield any better results.
Are there any other steps you would suggest taking?
Best,
James
