Agilex 7 I-Series "aocl diagnose acl0" error following OFS
May I know if you follow the guide in https://ofs.github.io/ofs-2024.3-1/hw/common/reference_manual/oneapi_asp/oneapi_asp_ref_mnl/#412-aocl_mmd_get_info?
Can you share the logging of running "aocl diagnose" and "aocl diagnose acl0"?
I haven't been using the reference manual you linked, but instead the oneAPI ASP Getting Started Guide: https://ofs.github.io/ofs-2024.2-1/hw/common/user_guides/oneapi_asp/ug_oneapi_asp/ . I'll look into the reference manual to see if it might help, however.
I also followed these guides to install the OFS/OPAE software and generate FIMs:
OFS/OPAE: https://ofs.github.io/ofs-2024.2-1/hw/common/sw_installation/pcie_attach/sw_install_pcie_attach/
FIM Generation: https://ofs.github.io/ofs-2024.2-1/hw/iseries_devkit/dev_guides/fim_dev/ug_ofs_iseries_dk_fim_dev/
Attached to this message are the log files for "aocl diagnose" and "aocl diagnose acl0" as you request. Let me know what you think!
Thank you for your help!
James
