Advice on CNN inference on Agilex 7 using oneAPI
Thank you for reaching out! I recommend checking out HLS4ML: HLS4ML GitHub Repository.
It is a framework designed to convert machine learning models from popular libraries like PyTorch and Keras into FPGA binaries. It integrates seamlessly with oneAPI by utilizing the DPC++/C++ compiler in the backend to generate IP blocks that represent the different components of your model, such as layers, activation functions, and more.
While HLS4ML is still a work in progress, it offers a good start point for which you can save massive time from implementing everything from scratch, including handling weights, pooling layers, and fixed-point arithmetic.
For a step-by-step guide on how to get started, you can explore their tutorials here: HLS4ML Tutorials. These Jupyter Notebooks walk you through the process from building and training a model to emulating it on an FPGA.
Let us know if you have any further questions.
