Why is there a fitter failure when using reference clock from HVIO System PLL for FABRIC_USE_CASE in the Agilex™ 3/ Agilex™ 5 FPGA GTS System PLL Clocks IP?
Description Due to a problem in the Quartus® Prime Pro Edition software version 25.3.1 and earlier, user will encounter fitter failure when they are using HVIO Reference Clock for Fabric_Use_Case. Resolution For a workaround, you need to set location assignment based on your selected devices in QSF assignment: Agilex™ 5 Family and Series Density Device Group Package Code Location Assignment A5E 013 A/B B23A/B32A/ M16A For Bank: 1A [SMHSSIPLLWRAP_X0_Y7_N1956] A5E 028 A/B B23A/B23A/ M16A For Bank: 1A [SMHSSIPLLWRAP_X0_Y7_N1956] 1B [SMHSSIPLLWRAP_X0_Y54_N1956] 4A [SMHSSIPLLWRAP_X121_Y7_N1956] A5E 065 A/B B23A/B32A 1A: [SMHSSIPLLWRAP_X121_Y7_N1956] 1B: [SMHSSIPLLWRAP_X0_Y54_N1956] 1C: [SMHSSIPLLWRAP_X0_Y101_N1956] 4A: [SMHSSIPLLWRAP_X185_Y7_N1956] 4B [SMHSSIPLLWRAP_X185_Y54_N1956] 4C [SMHSSIPLLWRAP_X185_Y101_N1956] A5D 064 A/B B32A 1A [SMHSSIPLLWRAP_X0_Y7_N2406] 1B [SMHSSIPLLWRAP_X0_Y15_N2406] 1C [SMHSSIPLLWRAP_X0_Y99_N2406] 1D [SMHSSIPLLWRAP_X0_Y107_N2406] 4A [SMHSSIPLLWRAP_X159_Y7_N2406] 4B [SMHSSIPLLWRAP_X159_Y15_N2406] 4C [SMHSSIPLLWRAP_X159_Y99_N2406] 4D [SMHSSIPLLWRAP_X159_Y107_N2406] The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.37Views0likes0CommentsError: Logic Generation failed to load results from Design Analysis and cannot get the list of IPs in the design
Description Due to a problem in the Quartus® Prime Pro Edition Software version 26.1 or earlier, you might see this error message during the Support-Logic Generation stage when compiling a design on the Windows* Operating System. This error occurs when Windows* long path support is disabled. Windows* limits the combined length of a file name and its path to 260 characters. If the project path exceeds this limit, the Quartus® Software cannot access required IP or design files. Resolution To work around this problem, enable Windows* long path support by updating the registry: a) Open Registry Editor: Press Windows Key + R, type regedit, and press Enter. b) Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem c) Find LongPathsEnabled. Double-click it and set "Value data" to 1. If the LongPathsEnabled doesn't exist, right-click, select New > DWORD (32-bit) Value, and name it LongPathsEnabled. d) Restart your computer. This error message will be enhanced in a future release of the Quartus ® Prime Pro Edition Software.7Views0likes0CommentsInternal Error: Sub-system: STA, File: /quartus/tsm/sta/sta_traversal_manager.cpp, Line: 2769
Description Due to a problem in the Quartus® Prime Pro Edition Software version 24.3 to 25.3.1, you might see this internal error at the Fitter Finalize stage when the design contains combinational loops. Static Timing Analysis analyzes timing graphs without loops. When a combinational loop is detected, Timing Analyzer replaces the loop with bypass edges whose delays represent the longest path through the loop. When new timing corners are added later in the finalize stage, the bypass edge delays may not be computed for all corners, causing an internal consistency check to fail and resulting in an internal error. Resolution This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 26.1.7Views0likes0CommentsWhy does the MIPI DSI‑2 FPGA IP design example fail when programming the FPGA on the Agilex® 3 FPGA and SoC C‑Series Development Kit?
Description Due to an issue in Quartus® Prime Pro Edition software version 26.1, users may encounter a failure when programming the FPGA with the .sof file generated by the MIPI DSI‑2 IP Design Example for the Agilex® 3 FPGA and SoC C‑Series Development Kit. This issue occurs because the design example generation script incorrectly maps the selected Agilex 3 development kit to an unintended target board. When configuring the FPGA using the Quartus Programmer, the following error may be reported: Error(18952): Error status: The device chain in Programmer does not match physical device chain. Expected JTAG ID code 0xXX Additionally, the FPGA part number shown in the generated example design may not match the FPGA device on the selected development kit. Resolution To work around this issue in Quartus® Prime Pro Edition software version 26.1, follow the steps below to generate the MIPI DSI‑2 IP Design Example for the correct Agilex® 3 FPGA device. 1. Open the Design Example Tab In the Quartus Prime Pro Edition software, open the MIPI DSI‑2 IP. Navigate to the Parameters window and ensure that the Design Example tab is selected at the top of the MIPI DSI‑2 IP GUI. 2. Select the Correct Target Board In the Target Development Kit section, open the Select Board drop‑down menu and choose the option that corresponds to your development kit, as shown in the table below: Development Kit Kit Part Number FPGA Part Number Target Board Option to Select Agilex® 3 FPGA and SoC C‑Series Development Kit DK‑A3W135BM16AEA A3CW135BM16AE6S Agilex® 3 FPGA C‑Series Development Kit Agilex® 3 FPGA C‑Series Development Kit DK‑A3Y135BM16AEA A3CY135BM16AE6S Agilex® 3 SoC C‑Series Development Kit Ensure that the selected target board option matches your development kit. 3. Generate the Design Example After selecting the correct target board option, click Generate Example Design and allow Quartus to complete the generation process. 4. Verify the FPGA Device Open the generated Quartus project and locate the device OPN in the Project Navigator. Verify that the device OPN (for example, A3CW135BM16AE6S) matches the FPGA part number listed for your development kit in the table above. If the device OPN matches, the design example has been generated correctly and can be programmed onto the FPGA. This problem affects only the target board selection mapping during design example generation for the Agilex® 3 FPGA and SoC C‑Series Development Kit. The MIPI DSI‑2 IP core and generated design examples are otherwise fully functional. This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.42Views0likes0CommentsWhy do I see rx_ready not asserting, or incorrect TX data rates in Agilex® 7 F‑Tile or Agilex® 5/3 FPGA GTS device transceiver simulations using the Quartus® Prime Pro 25.3.1 or earlier software with Siemens QuestaSim® Altera Edition software?
Description Due to a bug in the Quartus® Prime Pro 25.3.1 and earlier software for Agilex® 7 F‑Tile or Agilex ® 5/3 FPGA GTS devices, you may see the rx_ready signal not asserting, or incorrect TX data rates when simulating with the Siemens QuestaSim* Altera® Edition software. Resolution To work around this problem, you can update your design to the Quartus Prime Pro software version 26.1 and create a script that sets the following environment variables and then calls the Quartus Prime Pro software generated msim_setup.tcl file. set QUARTUS_SIM_LIB_DIR <quartus_installation>/quartus/eda/sim_lib2 set DEVICES_SIM_LIB_DIR <quartus_installation>/devices/sim_lib2 set ENABLE_QE_LIBRARY_COMPILATION "true" source msim_setup.tcl This problem will be fixed in a future version of the Quartus Prime Pro software.17Views0likes0CommentsWhy does niosv-download return “Invalid reset option” when executing reset from debug module?
Description Due to a problem in the Ashling RiscFree IDE for Altera® software, the niosv-download returns “Invalid reset option” when executing reset from debug module for designs targeting Nios ® V processor. The affected versions are: Software version 25.2.1 (version dated 9 th May 2025, paired with Quartus® Prime Pro software version 25.1.1 and Quartus® Prime Standard software version 25.1) Software version 25.3.1 (version dated 1 st Aug 2025, paired with Quartus® Prime Pro software version 25.3.1) Software version 25.4.1 (version dated 31 st Oct 2025, paired with Quartus® Prime Pro software version 26.1) The problem is caused by Ashling GDBServer failing to execute software reset (swreset), and niosv-download is using Ashling GDBServer to communicate with the processor. Thus, this failure prompts the “Invalid reset option” message when executing “niosv-download –r". Resolution To work around this problem, use the argument “-o” to change from Ashling GDBserver to OpenOCD. $ niosv-download –r -o This problem is fixed beginning with the Ashling RiscFree IDE for Altera® Quartus® software version 26.1.1-C, which is paired with Quartus® Prime Pro software version 26.1.1. Related Articles NIOS V/m dbg_reset_out signal (Q25.1 Std, MAX10) | Altera Community - 35238718Views0likes0CommentsWhy do the Configuration Intercept Interface, Control Shadow Interface, Configuration Extension Bus Interface, and VirtIO features not operate as expected when Configuration via Protocol is enabled in the GTS AXI Streaming IP for PCI Express*?
Description Due to a problem in the Quartus® Prime Pro Edition software version 26.1 and earlier, enabling the Configuration via Protocol (CvP) feature in the GTS AXI Streaming IP for PCI Express* automatically disables the Configuration Intercept feature within the IP. As a result, all features that rely on the Configuration Intercept Interface, or that internally utilize it, are also affected. Consequently, Vendor‑Specific Extended Capabilities (VSEC) implemented through the Configuration Extension Bus (CEB) Interface cannot be discovered during PCIe enumeration, VirtIO capabilities are not enumerated, and the Control Shadow Interface does not output configuration information as expected. Resolution This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition software.15Views0likes0CommentsWhich Protocols Support Spread Spectrum Clocking (SSC) on Agilex® 5 and Agilex® 3 FPGA Devices?
Description In the Agilex® 5 and Agilex® 3 FPGA device families, the Spread Spectrum Clocking (SSC) feature is supported only for specific protocol-based applications and can be optionally enabled for the following protocols: PCI Express (PCIe*) DisplayPort Hard Processor System (HPS) USB 3.1 Gen1 SATA/SAS (configured through the PMA/FEC Direct PHY IP) When using GTS transceivers, SSC is enabled by setting the "Spread Spectrum" option to "ENABLE", while keeping the “Enable TX FGT PLL fractional mode” option disabled in the GTS PMA/FEC Direct PHY IP. Resolution N/A18Views1like0CommentsWhy do setup and minimum pulse width timing violations occur in the LVDS SERDES IP Design Example?
Description Due to an issue in Quartus® Prime Pro Edition Software version 26.1 and earlier, you may encounter setup and minimum pulse width timing violations in the LVDS SERDES IP Design Example. This issue is caused by an incorrect value of the vco_data_rate_ratio parameter used in the LVDS SERDES IP, which leads to improper timing constraints and resulting violations. a { text-decoration: none; color: #464feb; } tr th, tr td { border: 1px solid #e6e6e6; } tr th { background-color: #f5f5f5; } Resolution To work around this issue, follow the steps below: Step 1: In the auto-generated file intel_lvds_core10_ph2_hw_ed_synth_intel_lvds_0_example_design_example_design_intel_lvds_core10_ph2_191_<string>.sv, Original: .vco_data_rate_ratio(0), Change to: .vco_data_rate_ratio(<correct_vco_data_rate_ratio>), Step 2: In the auto-generated file ed_synth_intel_lvds_0_example_design_example_design_intel_lvds_core10_ph2_191_<string>.sdc, add this SDC constraint set ip_params(vco_data_rate_ratio) <correct_vco_data_rate_ratio> Step 3: Re-compile the design The correct vco_data_rate_ratio parameter value based on the LVDS SERDES IP data rate (Mbps) shown in table below: Use the appropriate vco_data_rate_ratio based on the LVDS SERDES IP data rate: data_rate >= 600 Mbps 1 600 Mbps > data_rate >= 300 Mbps 2 data_rate < 300 Mbps 4 This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software. Related IP Core: LVDS SERDES IP34Views0likes0CommentsWhy does the Nios® V processor without data cache hang during a flash read operation using the Generic Serial Flash Interface (GSFI) IP HAL driver?
Description When performing a read operation on a flash device using the GSFI IP HAL driver, a Nios® V processor configured without a data cache may hang and stop functioning correctly due to an issue in the HAL driver. The HAL driver attempts to flush the data cache even when no data cache is present. This incorrect behavior places the processor into a non-deterministic state, which can cause the system to freeze. Resolution To work around this issue, update the following line in the intel_gsfi_read() function. Original: alt_dcache_flush_no_writeback((alt_u8*)qspi_flash_info->data_base + offset, length); Change to: #if ALT_CPU_DCACHE_SIZE > 0 alt_dcache_flush_no_writeback((alt_u8*)qspi_flash_info->data_base + offset, length); #endif This modification ensures that the data cache flush operation is performed only when a data cache is present. This issue will be fixed in a future Quartus® Prime Software release.18Views0likes0Comments
