Knowledge Base Article
Why Triple Speed Ethernet Shows Implicit Net Warning?
Description
The reset_n for pause generation stand/stop frame synchronizer is not driven properly. This causes reset_n to be stalled at VCC (inactive). Check the synthesis report for the following:
    • altera_eth_tse_std_synchronizer:XOFF_GEN_SYNC
    • altera_eth_tse_std_synchronizer:XON_GEN_SYNC
;reset_n;Input;Info;Stuck at VCC
If reset_n is stuck at GND, this feature will not work.
Resolution
There is no workaround for this issue.
This issue is fixed version 16.0 Update 2 of the Triple Speed Ethernet IP core.
Updated 11 months ago
Version 3.0
