Knowledge Base Article
Why reconfiguration fail after JIC Programming for Intel® Stratix® 10 devices?
Description
Intel® Stratix® 10 devices will fail in subsequent reconfiguration after JIC programming if you are using the Serial Flash Loader (SFL ) helper image (Factory default SFL image).
Resolution
Use one of the following workarounds to perform reconfiguration after JIC programming:
- If the Intel® Stratix® 10 device is configured, you can uncheck the SFL helper image configuration and continue with only the JIC programming.
- If the Intel Stratix 10 device is unconfigured, power cycle the device after the SFL helper image configuration and JIC programming.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 18.0.1.
Updated 3 months ago
