Knowledge Base Article
Why quartus_sign fails to generate a signed ccert for Agilex® 7 FPGA when running an AES root key provisioning command?
Description
When running the quartus_sign command for Agilex® 7 FPGA AES Root Key Provisioning, Quartus® Prime Pro Software fails with Error (20354).
Executing the following two commands fails when running the commands below:
## Create an unsigned AES compact certificate for the desired AES root key storage location:
quartus_pfg --ccert -o ccert_type=EFUSE_WRAPPED_AES_KEY -o password=passphrase.txt -o qek_file=aes_root.qek unsigned_efuse1.ccert
## Sign the compact certificate with the quartus_sign command or reference implementation:
quartus_sign --family=agilex7 --operation=sign --pem=aesccert1_private.pem --qky=aesccert1_sign_chain.qky unsigned_efuse1.ccert signed_efuse1.ccert
Resolution
You need to set the permission=0x40 when running this command.
Full command as below:
quartus_sign --family=agilex --operation=append_key \
--previous_pem=root0_private.pem \
--previous_qky=root0.qky \
--permission=0x40 \
--cancel=1 \
--input_pem=aesccert1_public.pem \
Additional Information
Please refer to Agilex® 7 FPGA Device Security User Guide for more details.
Updated 5 months ago
Version 6.0
