Knowledge Base Article
Why might Intel® Arria® 10 10GBASE-KR links get stuck during the Auto Negotiation stage with continuous IP resetting?
Description
Due to a problem with the1G/10GbE and 10GBASE-KR PHY Intel® Arria® 10 FPGA IP in the Intel® Quartus® Prime Software version 19.1 and earlier, IP reset will potentially cause the link to get stuck during the Auto Negotiation stage. This is because there is an arbitration design glitch in the reconfiguration interface logic inside the 10GBASE-KR IP, which causes an incorrect register read-modify-write operation during link training process. The wrong register behavior together with PMA channel re-calibration will bring transmitter channel into power down stage resulting in the link being stucked at the Auto Negotiation state.
Resolution
This problem is fixed starting with the Intel® Quartus® Prime Software version 19.2.
Updated 11 months ago
Version 3.0
