Knowledge Base Article
Why might I see de-asserted tx_pll_locked or tx_ready signals with my Agilex™ 7 FPGA transceiver F-Tile design when using the Quartus® Prime Pro Edition Software versions 23.1 and earlier?
Description
Due to a bug in the Quartus® Prime Pro Edition Software versions 23.1 and earlier, some F-Tile transmitters may remain in reset, which results in the tx_pll_locked or tx_ready signals being permanently de-asserted.
This intermittent problem may be seen with some Quartus® Prime Pro Edition Software compiled project programming files but not others. It only affects Quartus® Prime Pro Edition Software designs that use more than one Agilex™ 7 FPGA F-Tile.
Resolution
To fix this problem in the Quartus® Prime Pro Edition Software versions 22.4 and 23.1, install the following patches:
To fix this problem in the Quartus® Prime Pro Edition Software versions 22.3 and earlier, you must upgrade your design to Quartus® Prime Pro Edition Software version 22.4 or 23.1 and install the corresponding patch.
This problem will be fixed in a future revision of the Quartus® Prime Pro Edition Software.
Updated 8 months ago
Version 3.0
