Knowledge Base Article
Why might I see an incorrect frequency PreSICE transceiver calibration clock on Stratix® 10 devices?
Description
You might see an incorrect frequency PreSICE transceiver calibration clock on Stratix® 10 devices if the Quartus® Prime Software has cached an old version of your OSC_CLK_1 Quartus Settings File (QSF) assignment.
A PLL inside the FPGA receives the clock from the OSC_CLK_1 pin and provides a 250-MHz calibration clock to PreSICE. This clock calibrates all Stratix® 10 L-Tile and H-Tile device ATX PLLs, fPLLs, CDR/CMU PLLs, and PMAs.
The clock source and frequency are chosen in the Quartus® Prime Software project Device and Pin Option GUI or in the QSF file example assignment below.
set_global_assignment -name DEVICE_INITIALIZATION_CLOCK OSC_CLK_1_125MHz
If you have recently changed your Configuration Clock Source setting in the Quartus® Prime Software, an old version may be cached and used by the Quartus® Prime Software. This can result in an incorrect frequency calibration clock which may result in a higher Bit Error Rate (BER) on your Stratix® 10 L-Tile or H-Tile device transceiver channel.
Resolution
To work around this problem you can clean your Quartus® Prime Software database after you have changed your Configuration Clock Source setting. You can do this using the Quartus® Prime Software menus as shown below.
Project > Clean Project > All Revisions
You must then recompile your Quartus® Prime Software project.
Updated 11 months ago
Version 3.0
