Knowledge Base Article
Why MAX® 10 FPGA programming failed when I used .jbc file with altera-stapl/JAM-STAPL player?
Description
MAX® 10 FPGA programming with .jbc using altera-stapl/JAM-STAPL player failed with error log “No SLD hub”,”No SLD Node”, “Unrecognized device” and “Exit code = 6”.
However, programming through Quartus® using same JBC or POF is successful. Reading ID_CODE and USER_CODE are working.
Resolution
  1. Open the Quartus project’s programming or configuration-file generation settings.
  2. Enable “Enable real-time ISP to allow background programming” option.
  3. Regenerate the JAM file.
  4. Generate a new JBC from the newly created JAM file.
  5. Retry programming the MAX® 10 FPGA from the SoM using the new JBC.
Updated 3 months ago
Version 2.0
