Knowledge Base Article
Why isn't the BurstMin enhance scheduling working as intended in the F-tile Interlaken Intel® FPGA IP?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.4 and earlier, the BurstMin enhance scheduling for packet mode is not working as intended in the F-tile Interlaken Intel® FPGA IP.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software version 22.4 and earlier, you can set the Burst_min_in to 4'b0000. Otherwise, you can switch to Segment1 mode and handle the burst manually if BurstMin scheduling is not required.
This problem is scheduled to be fixed in a future version of the Intel® Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
