Knowledge Base Article
Why isn't the 1G/2.5G/5G/10G Multi-rate Ethernet PHY Stratix® 10 FPGA IP compliant to the PCS transmit code group-state diagram written in the IEEE 802.3 Clause 36 when sending /I2/ Ordered Set?
Description
Due to a problem in the 1G/2.5G/5G/10G Multi-rate Ethernet PHY Stratix® 10 FPGA IP, you might see the incorrect running disparity /I2/ Ordered Set in 1GbE mode.
According to the IEEE 802.3 Clause 36, /I2/ Ordered Set should be /K28.5-/D16.2+/ during IDLE duration.
However, the 1G/2.5G/5G/10G Multi-rate Ethernet PHY Stratix® 10 FPGA IP may generate an inverted running disparity of /I2/ Ordered Set which is /K28.5+/D16.2-/.
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition Software version 21.2.
Download and install Patch 0.45 below.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 22.3.
Updated 20 days ago
Version 3.0
