Knowledge Base Article
Why is there no video data coming from TX source when using the HDMI Intel® Arria® 10 FPGA IP Design Example with Bitec HDMI daughter card revision 6?
Description
Due to an incorrect assignment in the HDMI Intel® Arria 10 FPGA IP Design Example, HDMI IP does not work with the Bitec HDMI daughter card revision 4 and revision 6.
Resolution
To work around this problem, replace project directory/rtl/hdmi_rx/hdmi_rx_top.v with hdmi-rx-top.v
Support for the Bitec HDMI daughter card revision 4 and revision 6 cards are removed starting with the Intel® Quartus® Prime Pro Edition Software version 21.2.
Updated 8 months ago
Version 3.0No CommentsBe the first to comment
